Simple On/Off program won't execute
Wote the program and saved it.  A progress bar appears to show the save completes.  However, program does not execute at the defined time.  Check of "Summary" for the program reveals "Activity: Not Loaded" and "Status: Out of Memory."  What does this mean and how do I correct yhe problem?
Solved by MrBill
Thanks, MrBill.
So I checked;  Firmware is "UD994_OADR v5.3.0" while the UI is "UD994 v4.9.0"
What are the steps to make them the same?
MrBill,
Finally got the the Firmaware and UI versions to match - bith are now v5.3.0.
Not Loaded and Out of Memory entries are gone.
I'll see how the program responds at sunset today.
Thanks for the help so far  . . .
2 hours ago, JMathers said:
MrBill,
You may or may not need to re-save the program to get the program to work. (since it was actually created with a mismatched versions.)   If so, you can likely just open it, click on any program line, hit the update button, then the save button again.
