Admin Console won't load programs
Hi,
Have an ISY with no updates for several years.  Tried to go in and edit a program. Console loaded, but every time I go to the programs tab it locks up showing a popup saying "loading scene widgets". Have rebooted the laptop, checked java version, and rebooted the isy to no avail.
Any ideas?
Paul
Solved by bgrubb1
3 minutes ago, Techman said:
Most likely your firmware and UI don't match. What's your current firmware version?
Clear your java cache, including checking the box "installed applications" then download the IoX Launcher from here:
https://isy.universal-devices.com/start.jnlp
Already did this. Cleared cache and installed fresh Java.  Also used used a fresh start.jlnp from the same link.
Didn't work.
Paul
35 minutes ago, Techman said:
What's your current firmware and UI versions?
firmware 5.3.4. Not sure where you find UI version.
Admin Console is very slow or hangs
  • If the admin console is slow to respond, it is likely you need to increase the amount of memory allocated to the Java runtime (JRE).
  • Open the Java Control Panel, select Java tab, press View button, then add or modify the Runtime Parameter -Xmx to the following:
    • -Xmx512m
  • Press Ok to close the window, then Press Apply to save the changes
The UI and firmware versions can be found in the Admin Console under HELP | ABOUT
One thing you can try is removing power from the ISY, then remove the SD card and reseat it.
Let me know if that resolves the problem.
    • -Xmx512m
Thanks!!! It worked and the console loaded so much faster. You're a life saver.
Paul
