Hi,
Have an ISY with no updates for several years. Tried to go in and edit a program. Console loaded, but every time I go to the programs tab it locks up showing a popup saying "loading scene widgets". Have rebooted the laptop, checked java version, and rebooted the isy to no avail.
Any ideas?
Paul
Admin Console is very slow or hangs
If the admin console is slow to respond, it is likely you need to increase the amount of memory allocated to the Java runtime (JRE).
Open the Java Control Panel, select Java tab, press View button, then add or modify the Runtime Parameter -Xmx to the following:
-Xmx512m
Press Ok to close the window, then Press Apply to save the changes
