Parsing Errors causes node server offline
I monitor the online status of this node server with a program and the node server briefly goes offline a few times a day.  Here are a couple of errors I say in the log that coincides with the offline.
2023-08-22 16:51:20,218 Thread-1613 udi_interface      ERROR    station:Query: Parsing failed: string indices must be integers
2023-08-22 16:51:20,218 Thread-1613 udi_interface      INFO     station:setState: ecfabc15d6 status set to 0
2023-08-22 16:51:20,218 Thread-1613 udi_interface      INFO     station:setState: 8caab5c78f status set to 0
2023-08-22 16:51:20,340 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8caab5c78f :: ST to 0 UOM 2
2023-08-22 16:51:35,473 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ecfabc15d6 :: ST to 0 UOM 2
2023-08-22 16:29:19,882 Thread-1588 udi_interface      ERROR    station:Query: Parsing failed: string indices must be integers
2023-08-22 16:29:19,882 Thread-1588 udi_interface      INFO     station:setState: ecfabc15d6 status set to 0
2023-08-22 16:29:19,882 Thread-1588 udi_interface      INFO     station:setState: 8caab5c78f status set to 0
2023-08-22 16:29:20,005 MQTT       udi_interface.interface INFO     interface:_message: Successfully set 8caab5c78f :: ST to 0 UOM 2
2023-08-22 16:29:35,025 MQTT       udi_interface.interface INFO     interface:_message: Successfully set ecfabc15d6 :: ST to 0 UOM 2
Any idea what's causing these parsing errors?
Thank you in advance.
Solved by bpwwer
when the node server queries the Ambient server for data, what it gets back is not valid data.  The node server then marks the station as offline until a query responses with valid data.
