Hello everyone,
This is the support thread for PG3x v3.2.3.
After updating to 3.2.3, please click on System | Reinstall all node servers, which will reinstall all your node servers including the new UDI python interface 3.2.0.
If you were on PG3x 3.2.1+ and you already re-installed your node servers, there is no need to re-install them as there has been no changes to UDI Python interface with 3.2.2 or 3.2.3.
Hello everyone,
We found that a system update is causing issues with node server startup on eisy.
We are working on a permanent fix.
But for now, here's a solution:
ssh to your system (on Windows, you can use putty)
Run these 2 commands:
sudo pip3 uninstall aioquic
sudo pip3 install aioquic
You can ignore the warnings.
This will reinstall aioquic at the same version (0.9.21). However it does check dependancies. On my system, this un
