Support thread for: PG3x v3.2.4 (OUTDATED)
4 minutes ago, 4481hoods said:
Did the upgrade. Polisy will not start! Did a hard boot. Can Putty in!
Help!!!!
Please check the PG3x log using:
tail -f /var/polyglot/pg3/logs/pg3-current.log
If you see nothing useful, please open a ticket, and attach the content of:
tail -n 200 /var/polyglot/pg3/logs/pg3-current.log
Same here PG3x not starting after upgrade, ticket opened.
For now, here's a temporary solution that should work.
SSH to your eisy and use these commands:
cd /var/polyglot
sudo service pg3 stop
sudo rm -rf node_modules
sudo pkg remove pg3x
sudo pkg install pg3x
sudo service pg3 onestart
cd /var/polyglot
sud
That worked.
I have been trying to update v3.2.4, but thus far without success.  I thought when I update my Polisy via the Upgrade Package command in the AC that Polyglot would also be updated along the way. This does not seem to be the case. What do I need to do here?
This means you are on PG3, not PG3x.
To upgrade PG3 to PG3x:
https://wiki.universal-devices.com/index.php?title=Polisy:User_Guide#Upgrading_to_PG3x
