Since you can't toggle outputs in the ELK M1 directly, I tried to turn on Output 2 to test my siren.  I made output 1 and 2 visible, refreshed topology in ISY and the zones appeared in the ELL module of ISY.  However, when I turn output 2 on in ISY, the status updates to 'ON' but nothing happens.  When I do this for Output 1, my indoor siren sounds.  Only difference is Output 2 is set to voltage output in ELK because its a siren instead of a speaker.  I was starting to think I had a wiring issue even though ELK wasnt reporting a a supervisory problem.  Then I created a rule in ELK console directly to turn on Output 2 when I open a door, and it worked with no issues.  What could be preventing ISY from turning on that output?
Edited by n8huntsman
      37.6k
      376.1k
