Hub stopped showing status for nodes, trying to connect to an Ip address which is not the hub
I do have .13 reserved in the router. It did used to be .12 when it wasnt static and it had changed maybe a couple weeks ago while i was messing around with some vpn stuff. But since this morning i have updated polisy to 5.7 and upgraded to pg3x. and have restarted the system a few times all while having static ip of the harmony at .13 so not sure why the logs would ever be showing the unable to connect to the .12 nag since.
setting clear_hubs to 1, then wait a few seconds and run discover again has fixed this issue.
