Migrated from 994i to esiy, and ployglot v2 to v3 mainly for myq.
Everything was working great until early September when MyQ stopped working for Ployglot v2, so I bought the eisy.
The migration was frustrating as all heck.  Getting the local access using a PC was way less frustrating then the mobile app.  The big missing piece was -- default login info for local eisy is admin admin.
I purchased the 12.95 subscription from @Goose66, and thank you for your work on this.
I think that I went wrong when I said upgrade the polyglot slot, which was the only slot 3.  I didn't want to have to go in and redo program references so I hoped it would work.  It looked like it didn't but there is an error when it tries to log in.  See log below, removed password and email.
2023-10-01 13:20:49,504 MainThread udi_interface      INFO     polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-10-01 13:20:49,504 MainThread udi_interface      INFO     __init__:<module>: UDI interface initializing
2023-10-01 13:20:49,504 MainThread udi_interface      INFO     __init__:<module>: User=0021b9026703_3
2023-10-01 13:20:49,504 MainThread udi_interface      INFO     __init__:<module>: Home=/var/polyglot/pg3/ns/0021b9026703_3
2023-10-01 13:20:49,505 MainThread udi_interface      INFO     __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b9026703_3
2023-10-01 13:20:49,505 MainThread udi_interface      INFO     __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6Njc6MDMiLCJwcm9maWxlTnVtIjozLCJsb2dMZXZlbCI6IkRFQlVHIiwidG9rZW4iOiJySVQ5UEkhPUwxKk5PV0VIIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjIuOCIsImlzeVZlcnNpb24iOiI1LjcuMCIsImVkaXRpb24iOiJGcmVlIn0=
2023-10-01 13:20:49,505 MainThread udi_interface      INFO     __init__:<module>: Loading interface module
2023-10-01 13:20:49,558 MainThread udi_interface      INFO     interface:<module>: Loading MQTT module
2023-10-01 13:20:49,997 MainThread udi_interface      INFO     interface:<module>: MQTT module loaded
2023-10-01 13:20:50,211 MainThread udi_interface      INFO     __init__:<module>: Loading udi_interface module
2023-10-01 13:20:50,211 MainThread udi_interface      INFO     __init__:<module>: Loading node module
2023-10-01 13:20:50,211 MainThread udi_interface      INFO     __init__:<module>: Loading custom module
2023-10-01 13:20:50,212 MainThread udi_interface      INFO     __init__:<module>: Loading isy module
2023-10-01 13:20:50,212 MainThread udi_interface      INFO     __init__:<module>: UDI interface initialized
2023-10-01 13:20:50,212 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.2 Starting...
2023-10-01 13:20:50,243 MainThread udi_interface.interface INFO     interface:__init__: Initialization received from Polyglot V3 3.2.8  [ISY: 5.7.0, Slot: 3]
2023-10-01 13:20:50,243 MainThread udi_interface.interface INFO     interface:__init__: Connect: Network Interface: {'addr': '192.168.111.229', 'netmask': '255.255.255.0', 'broadcast': '192.168.111.255'}
2023-10-01 13:20:50,244 MainThread udi_interface      INFO     myqns:run: Starting MyQ node server...
2023-10-01 13:20:50,244 Interface  udi_interface.interface INFO     interface:_startMqtt: Connecting to MQTT... localhost:8883
2023-10-01 13:20:50,244 MainThread udi_interface.interface WARNING  interface:_get_server_data: get_server_data: failed to read file server.json: [Errno 2] No such file or directory: 'server.json'
2023-10-01 13:20:50,245 Interface  udi_interface.interface INFO     interface:_startMqtt: Using SSL cert: 0021b9026703_3.cert key: 0021b9026703_3.key ca: /usr/local/etc/ssl/certs/ud.ca.cert
2023-10-01 13:20:50,245 MainThread udi_interface.interface WARNING  interface:send: MQTT Send waiting on connection :: {'config': {'version': '3.2.22', 'requestId': False}}
2023-10-01 13:20:50,295 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Connected with result code 0 (Success)
2023-10-01 13:20:50,295 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:67:03_3 -  MID: 2 Result: 0
2023-10-01 13:20:50,338 MQTT       udi_interface.interface INFO     interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,)
2023-10-01 13:20:53,264 MainThread udi_interface.interface INFO     interface:updateProfile: Sending Install Profile command to Polyglot.
2023-10-01 13:20:53,290 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message getAll
2023-10-01 13:20:53,290 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING getAll
2023-10-01 13:20:53,290 Thread-2   udi_interface.custom DEBUG    custom:load: CUSTOM: load {'username': '########@gmail.com', 'password': '##################'}
2023-10-01 13:20:53,290 Command    udi_interface.custom DEBUG    custom:load: CUSTOM: load {'login_error': 'There was an error connecting to the MyQ service. Please check the log files and correct the issue before restarting the nodeserver.'}
2023-10-01 13:20:53,291 Thread-2   udi_interface.custom DEBUG    custom:load: CUSTOM:  -- checking username / ########@gmail.com
2023-10-01 13:20:53,291 Command    udi_interface.custom DEBUG    custom:load: CUSTOM:  -- checking login_error / There was an error connecting to the MyQ service. Please check the log files and correct the issue before restarting the nodeserver.
2023-10-01 13:20:53,291 Thread-2   udi_interface.custom DEBUG    custom:load: CUSTOM:  -- checking password / ##################
2023-10-01 13:20:53,291 Command    udi_interface.interface DEBUG    interface:_handleInput: Key nsdata should be passed to node server.
2023-10-01 13:20:53,292 Command    udi_interface.interface DEBUG    interface:_handleInput: Key oauth should be passed to node server.
2023-10-01 13:20:53,292 Thread-7   udi_interface      DEBUG    myqns:start: In Nodeserver start()...
2023-10-01 13:20:53,293 Thread-7   udi_interface.custom DEBUG    custom:clear: CUSTOM: Clear  ...saving
2023-10-01 13:20:53,293 Thread-7   udi_interface.custom INFO     custom:_save: Sending data notices to Polyglot.
2023-10-01 13:20:53,293 Thread-7   udi_interface.interface DEBUG    interface:send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]}
2023-10-01 13:20:53,293 Thread-7   udi_interface.node DEBUG    node:_updateDrivers: Update service default GPV to 1 / 25
2023-10-01 13:20:53,294 Thread-7   udi_interface.node DEBUG    node:_updateDrivers: Update service default ST to 0 / 2
2023-10-01 13:20:53,294 Thread-7   udi_interface.custom DEBUG    custom:__init__: CUSTOM: Initialzing _rawdata to empty
2023-10-01 13:20:53,294 Thread-7   udi_interface.interface INFO     interface:addNode: Adding node MyQ Service(service) [None]
2023-10-01 13:20:53,294 Thread-7   udi_interface.interface DEBUG    interface:send: PUBLISHING {'addnode': [{'address': 'service', 'name': 'MyQ Service', 'nodeDefId': 'SERVICE', 'primaryNode': 'service', 'drivers': [{'driver': 'ST', 'value': 0, 'uom': 2}, {'driver': 'GPV', 'value': '1', 'uom': 25}], 'hint': [0, 0, 0, 0], 'private': None, 'rename': False}]}
2023-10-01 13:20:53,294 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message getNsInfo
2023-10-01 13:20:53,295 Thread-7   udi_interface.interface INFO     interface:setController: Using node "service", driver "GPV" for connection status.
2023-10-01 13:20:53,295 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING getNsInfo
2023-10-01 13:20:53,295 Thread-7   udi_interface.interface DEBUG    interface:send: PUBLISHING {'setController': {'node': 'service', 'driver': 'GPV'}}
2023-10-01 13:20:53,314 MQTT       udi_interface.interface INFO     interface:_message: custom data response {'customparamsdoc': '<h2>MyQ  NodeServer Configuration</h2>\n\n<p>Add the required Custom Configuration Parameters for "username" and "password" below for your MyQ account. Note that the node server won\'t work with accounts tied to an Amazon, Google, or Apple login -- you must have a MyQ account. Once the "MyQ Service" appears in the Admin Console, click the "Discover Devices" button for the node to discover MyQ bridges (hubs) and devices linked to your account. If your account has devices linked for different homes, enter the "homename" Custom Configuration Parameter below to specify which home to load devices for.</p>\n\n<h4>Advanced Configuration:</h4>\n\n<ul>\n<li>key: shortPoll, value: polling interval for MyQ cloud service in "active" polling mode (defaults to 20 seconds - minimum polling interval).</li>\n<li>key: longPoll, value: polling interval for MyQ cloud service when not in "active" polling mode (defaults to 60 seconds).</li>\n</ul>\n\n<h4>Custom Configuration Parameters:</h4>\n\n<ul>\n<li>key: username, value: username (email address) for MyQ online account (required)</li>\n<li>key: password, value: password for MyQ online account (required)</li>\n<li>key: homename, value: home name from which to load devices (if your account has access to multiple homes) (optional)</li>\n</ul>\n'}
2023-10-01 13:20:53,316 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = customparamsdoc
2023-10-01 13:20:53,357 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message notices
2023-10-01 13:20:53,357 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING notices
2023-10-01 13:20:53,358 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = notices
2023-10-01 13:20:53,358 Command    udi_interface.custom DEBUG    custom:load: CUSTOM: load {}
2023-10-01 13:20:53,398 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message setController
2023-10-01 13:20:53,398 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING setController
2023-10-01 13:20:53,398 Command    udi_interface.interface DEBUG    interface:_handleInput: connection status node/driver update
2023-10-01 13:20:53,458 MQTT       udi_interface.interface INFO     interface:_message: Profile installation finished
2023-10-01 13:20:53,500 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message addnode
2023-10-01 13:20:53,500 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING addnode
2023-10-01 13:20:53,501 Thread-9   udi_interface      DEBUG    nodes:start: In start() for MyQ Service node...
2023-10-01 13:20:53,501 Command    udi_interface.interface DEBUG    interface:_handleResult: add node response: {'id': '47acc836-0694-40dd-b73b-3eb40da72c1f', 'uuid': '00:21:b9:02:67:03', 'profileNum': 3, 'address': 'service', 'name': 'MyQ Service', 'nodeDefId': 'SERVICE', 'nls': None, 'hint': '0x00000000', 'controller': 1, 'primaryNode': 'service', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1696188718719, 'timeModified': 1696191653347, 'dbVersion': 1}
2023-10-01 13:20:53,501 Thread-9   udi_interface      INFO     nodes:start: Establishing initial MyQ connection...
2023-10-01 13:20:53,501 Thread-9   udi_interface      DEBUG    myqapi:loginToService: in API loginToService()...
2023-10-01 13:20:53,502 Thread-9   udi_interface      INFO     myqapi:_oAuthRetrieveToken: Logging in and retrieving access token via oAuth...
2023-10-01 13:20:53,574 Thread-9   udi_interface      WARNING  myqapi:_oAuthRequest: Network/server error logging into MyQ service: 429 Client Error: Too Many Requests for url: https://partner-identity.myq-cloud.com/connect/authorize?client_id=IOS_CGI_MYQ&code_challenge=FCziqTLLAGz_Gdngx19K61LAt6tSyAwDVDfsK-Qp250&code_challenge_method=S256&redirect_uri=com.myqops%3A%2F%2Fios&response_type=code&scope=MyQ_Residential+offline_access
2023-10-01 13:20:53,574 Thread-9   udi_interface      DEBUG    myqapi:_oAuthRetrieveToken: Error in Step 1 of oAuth flow.
2023-10-01 13:20:53,574 Thread-9   udi_interface.custom DEBUG    custom:__setitem__: CUSTOM: login_error = There was an error connecting to the MyQ service. Please check the log files and correct the issue before restarting the nodeserver. ...saving
2023-10-01 13:20:53,574 Thread-9   udi_interface.custom INFO     custom:_save: Sending data notices to Polyglot.
2023-10-01 13:20:53,574 Thread-9   udi_interface.interface DEBUG    interface:send: PUBLISHING {'set': [{'key': 'notices', 'value': {'login_error': 'There was an error connecting to the MyQ service. Please check the log files and correct the issue before restarting the nodeserver.'}}]}
2023-10-01 13:20:53,576 Thread-9   udi_interface.node DEBUG    node:setDriver: service:MyQ Service No change in ST's value
2023-10-01 13:20:53,593 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message notices
2023-10-01 13:20:53,593 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING notices
2023-10-01 13:20:53,594 Command    udi_interface.custom DEBUG    custom:load: CUSTOM: load {'login_error': 'There was an error connecting to the MyQ service. Please check the log files and correct the issue before restarting the nodeserver.'}
2023-10-01 13:20:53,594 Command    udi_interface.custom DEBUG    custom:load: CUSTOM:  -- checking login_error / There was an error connecting to the MyQ service. Please check the log files and correct the issue before restarting the nodeserver.
2023-10-01 13:20:53,635 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = notices
I've stopped it an maybe it will work in a while, but I'm thinking this might be something to do with the agent not being updated since I used the same node, and it's not unique to me. 👍👍
Edited by toddhutch
The previous error dealing with UserAgent was an HTTP 403 error, I believe. You're getting a 429 Client Error: Too Many Requests. I will have to look into it. In the meantime, what's your shortPoll and longPoll set to in your Advanced Configuration?
I checked my log files under PG3x since my migration last week. I got the same 429 - Too many requests error back on 9/26 on every longpoll oAuth token refresh for approx. 3 hours around 1:00am and again on 9/29 for a similar timeframe. Otherwise the MyQ node server has run fine since the migration.
At this point, it looks like it's a transient error having something to do with the partner Chamberlain is using for oAuth authentication. I don't see anything about it in the Issues for the pymyq library (from which the node server was patterned). If a bunch of people start getting it all the time, I will look into it further.
Edited by Goose66
@Goose66  I left the short and long default, I just started the service, and it worked perfectly.  I think it was probably because I had the polyglot v2 running up until minutes before I did this.  All good!
Excellent. I will try to keep an eye on it. I may need to back off on the frequency it tries to refresh the token on initial failure. It may just be a simple longPoll change, or it may need its own period setting.
Edited by Goose66
Here's what the two instances I mentioned above look like: It gets an initial error in oAuth, e.g. a 401 error (not uncommon). It retries every minute (longPoll interval) for 6 or 7 minutes, then the server starts responding with the 429 - Too many requests error. So I think I need a longer retry on failure than the longPoll interval, or maybe after some number of failure retries, I crank down the frequency of retries. I'll put a TODO in the code for the next version.
The 429 error is starting to crop up in other circles. Evidently there is a header included in these that specify how long you need to wait before retrying and the numbers are like 30 minutes or more, so I may need to rework the retry logic to find and start using this number on the retry. Note again this seems to be somewhat limited to when the node server is restarted and it has to acquire a whole new oAuth token for access.
