Can a Insteon Motion Sensor II Turn On and "Off" a Insteon Light Bulb without a Scene
Hi All,
I have an Insteon question and thought the experienced folks here could assist.  I have successfully upgraded my ISY to the Polisy, now running just the Polisy.
1.  The question relates to the Insteon MS II.  I have the MS II successfully turning on a Insteon Light Bulb, by linking the MS II directly to the Bulb.  It won't turn off then the MS II stops detecting motion.  I believe I have read that in order to do both, turn on and off, it will require a scene.  Is this correct or am I missing something thru the direct linking process?
Thanks for the support.
Edited by BoomerangThree
Solved by Techman
You could do it with a program
IF
      Motion sensor is switched on
THEN
      Turn on light
       Wait xx minutes
       Turn off light
ELSE
