Z-Matter - USB2 or USB3
Just curious is the Z-Matter Dongle for the EISY is a USB 2 or 3 device?  I am putting it on an extension cable and the one I have is USB-2.  I can't image it needs anything more than that.  I don't have any Z-Wave devices yet to test it, so asking here.
It is white inside the port, not blue...so assume USB2 but just to be sure.
Edited by ulrick65
  • 3 months later...
Just bumping this as I have essentially the same question.
Can I remotely place the z wave/zigbee dongle using a USB extension cable? It seems intuitively okay. If yes, distance considerations/limitations?
Yes, USB 2.0 has a recommended maximum cable lenght of 15 feet. USB 3.x has a shorter recommended length of about 9 feet
Again, thanks....Not seeing much about this... are many people separating the physical eisy box and the dongle?
Chris
I did, and I know of a few others. It allows you to position the dongle's antennas away from obstructions for better RF coverage. It also eliminates potential strain on the eisy USB port.
I use extension cables:
The EISY sits in my server rack.
The PLM is plugged in at my power panel (a separate receptacle and I have a phase bridge installed) and is connected to the EISY via a 35-foot USB 3.0 cable.
The zMatter Dongle is mounted in my basement ceiling at the end of a 16-foot USB 2.0 cable.
Everything works perfectly.
Edited by ulrick65
