Is There a Procedure for Passing Elk M1G Updates to Polyglot through the Elk Node Server?
When I installed my Elk Node Server initially to Polyglot in Polisy, there were two tasks defined in the ElkRP under Automation-Tasks.
After the installation, these two tasks show in the Polisy Admin Console under the Elk Controller list and the list of nodes in Polyglot.
So, yesterday, I added a third Task using ElkRP.
However, this third task failed to appear in the list of Elk nodes in Polyglot.
So, I tried restarting Polyglot, restarting Polisy and restarting the Elk Node Server. It never appeared.
This evening it showed up after much fiddling about among the three players, Elk, Polyglot and Admin Console.
I suspect that after such a change all 3 players have to be reset in some way and I just happened to get it right.
So, my question is this:
Does anyone have a procedure to follow so changes in the M1G are passed through the Elk Node Server to Polyglot?
Solved by phawtrey
Thank you Jimbo
I added a new task to Elk,and restarted the Node server. Oddly, the new task did not show up in the list of nodes in the Polyglot, but it did show up in the Admin Console under Elk Controller.  So, thank you for your help.
