New install no devices found
Go to solution Solved by Jimbo.Automates,
Just purchased and installed Kasa node.  I have 1 KL130 bulb. No nodes showing.
PG3x Version 3.2.10
Frontend Version: 3.2.10
IoX Version: 5.7.0   Connected
Kasa version: Current Version: 3.1.0
Log repeating as follows:
023-11-03 09:21:02,074 MainThread udi_interface      INFO     __init__:<module>: UDI interface initializing
2023-11-03 09:21:02,074 MainThread udi_interface      INFO     __init__:<module>: User=000db9532b58_1
2023-11-03 09:21:02,075 MainThread udi_interface      INFO     __init__:<module>: Home=/var/polyglot/pg3/ns/000db9532b58_1
2023-11-03 09:21:02,076 MainThread udi_interface      INFO     __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/000db9532b58_1
2023-11-03 09:21:02,077 MainThread udi_interface      INFO     __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MGQ6Yjk6NTM6MmI6NTgiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IldBUk5JTkciLCJ0b2tlbiI6IjM/KD93KTQqSXB5KnZEWmIiLCJtcXR0SG9zdCI6ImxvY2FsaG9zdCIsIm1xdHRQb3J0Ijo4ODgzLCJzZWN1cmUiOjEsImlzUEczeCI6dHJ1ZSwicGczVmVyc2lvbiI6IjMuMi4xMCIsImlzeVZlcnNpb24iOiI1LjcuMCIsImVkaXRpb24iOiJTdGFuZGFyZCJ9
2023-11-03 09:21:02,077 MainThread udi_interface      INFO     __init__:<module>: Loading interface module
2023-11-03 09:21:02,364 MainThread udi_interface      INFO     interface:<module>: Loading MQTT module
2023-11-03 09:21:02,586 MainThread udi_interface      INFO     interface:<module>: MQTT module loaded
2023-11-03 09:21:04,535 MainThread udi_interface      INFO     __init__:<module>: Loading udi_interface module
2023-11-03 09:21:04,540 MainThread udi_interface      INFO     __init__:<module>: Loading node module
2023-11-03 09:21:04,541 MainThread udi_interface      INFO     __init__:<module>: Loading custom module
2023-11-03 09:21:04,541 MainThread udi_interface      INFO     __init__:<module>: Loading isy module
2023-11-03 09:21:04,542 MainThread udi_interface      INFO     __init__:<module>: UDI interface initialized
2023-11-03 09:21:04,543 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.3 Starting...
2023-11-03 09:21:04,554 MainThread udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2023-11-03 09:21:04,555 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db9532b58_1/kasa-poly.py", line 12, in <module>
2023-11-03 09:21:04,556 MainThread udi_interface      ERROR    udi_interface:write: from nodes import VERSION,Controller
2023-11-03 09:21:04,557 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db9532b58_1/nodes/__init__.py", line 9, in <module>
2023-11-03 09:21:04,559 MainThread udi_interface      ERROR    udi_interface:write: from .SmartDeviceNode      import SmartDeviceNode
2023-11-03 09:21:04,560 MainThread udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db9532b58_1/nodes/SmartDeviceNode.py", line 8, in <module>
2023-11-03 09:21:04,561 MainThread udi_interface      ERROR    udi_interface:write: from kasa import SmartDeviceException
2023-11-03 09:21:04,562 MainThread udi_interface      ERROR    udi_interface:write: ModuleNotFoundError
2023-11-03 09:21:04,563 MainThread udi_interface      ERROR    udi_interface:write: :
2023-11-03 09:21:04,564 MainThread udi_interface      ERROR    udi_interface:write: No module named 'kasa'
Edited by ThisIsTheWay
Yes. You'll need to allow UDP discovery across the network if that's possible. There are also options to manually add devices or networks in the config, although those options have not been extensively tested.
Sent from my Pixel 8 Pro using Tapatalk
I moved the device to the same subnet 192.168.1.xxx.   Still not finding the device. Please offer guide for manual addition.
Did this get resolved?  I seem to have the same (or very similar) issue.  I just installed a new eISY (formerly using ISY994 and ployglot running on Raspberry Pi).  I'm trying the trial version of Kasa.
I can start a new thread if needed.  I'm just doing my due diligence by searching the forum for similar issues before I open new topics (already fixed a couple of unrelated issues by following other threads).
Yes, this issue was resolved. Make sure you have recently run an update packages so you have the latest release then reinstall the nodeserver.
      37.8k
      377.9k
