Controller:handler_start: Timed out waiting for handlers to startup
copperstar
Go to solution Solved by copperstar,
After an upgrade packages run, the Elk nodeserver is having problems.
After several restarts and even a restore to previous, I continue to get ;
Although the NodeServer in IoX displays connected, there is no data available from the Elk NodeServer.
Any ideas on restoring the server? Thanks
Full error log below;
2023-11-17 19:14:42,977 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-11-17 19:14:42,979 MainThread udi_interface INFO __init__:<module>: UDI interface initializing
2023-11-17 19:14:42,980 MainThread udi_interface INFO __init__:<module>: User=000db953d8b0_1
2023-11-17 19:14:42,980 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/000db953d8b0_1
2023-11-17 19:14:42,981 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/000db953d8b0_1
2023-11-17 19:14:42,982 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MGQ6Yjk6NTM6ZDg6YjAiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IkVSUk9SIiwidG9rZW4iOiI5dStoVm5hZHVYQURnJkx1IiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjIuMTYiLCJpc3lWZXJzaW9uIjoiNS43LjEiLCJlZGl0aW9uIjoiU3RhbmRhcmQifQ==
2023-11-17 19:14:42,983 MainThread udi_interface INFO __init__:<module>: Loading interface module
2023-11-17 19:14:43,576 MainThread udi_interface INFO interface:<module>: Loading MQTT module
2023-11-17 19:14:43,791 MainThread udi_interface INFO interface:<module>: MQTT module loaded
2023-11-17 19:14:45,615 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module
2023-11-17 19:14:45,620 MainThread udi_interface INFO __init__:<module>: Loading node module
2023-11-17 19:14:45,621 MainThread udi_interface INFO __init__:<module>: Loading custom module
2023-11-17 19:14:45,621 MainThread udi_interface INFO __init__:<module>: Loading isy module
2023-11-17 19:14:45,622 MainThread udi_interface INFO __init__:<module>: UDI interface initialized
2023-11-17 19:14:45,623 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.4 Starting...
2023-11-17 19:14:45,902 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.2.16 [ISY: 5.7.1, Slot: 1]
2023-11-17 19:14:45,904 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.0.19', 'netmask': '255.255.255.0', 'broadcast': '192.168.0.255'}
2023-11-17 19:14:45,908 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883
2023-11-17 19:14:45,914 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: controller not found in database.
2023-11-17 19:14:45,915 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 000db953d8b0_1.cert key: 000db953d8b0_1.key ca: /usr/local/etc/ssl/certs/ud.ca.cert
2023-11-17 19:14:45,916 MainThread udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2023-11-17 19:14:45,918 MainThread udi_interface.interface INFO interface:addNode: Adding node ELK Controller(controller) [None]
2023-11-17 19:14:45,919 MainThread udi_interface.interface INFO interface:setController: Using node "controller", driver "ST" for connection status.
2023-11-17 19:14:46,017 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success)
2023-11-17 19:14:46,020 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:53:d8:b0_1 - MID: 2 Result: 0
2023-11-17 19:14:46,066 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,)
2023-11-17 19:14:46,149 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2023-11-17 19:14:57,444 Thread-8 udi_interface ERROR Controller:handler_start: Timed out waiting for handlers to startup
2023-11-17 19:14:57,448 Thread-8 udi_interface ERROR udi_interface:write: Exception in thread
2023-11-17 19:14:57,449 Thread-8 udi_interface ERROR udi_interface:write: Thread-8
2023-11-17 19:14:57,450 Thread-8 udi_interface ERROR udi_interface:write: :
2023-11-17 19:14:57,451 Thread-8 udi_interface ERROR udi_interface:write: Traceback (most recent call last):
2023-11-17 19:14:57,452 Thread-8 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner
2023-11-17 19:14:57,460 Thread-8 udi_interface ERROR udi_interface:write: self.run()
2023-11-17 19:14:57,462 Thread-8 udi_interface ERROR udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run
2023-11-17 19:14:57,472 Thread-8 udi_interface ERROR udi_interface:write: self._target(*self._args, **self._kwargs)
2023-11-17 19:14:57,483 Thread-8 udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db953d8b0_1/nodes/Controller.py", line 167, in handler_start
2023-11-17 19:14:57,492 Thread-8 udi_interface ERROR udi_interface:write: self.exit()
2023-11-17 19:14:57,493 Thread-8 udi_interface ERROR udi_interface:write: AttributeError
2023-11-17 19:14:57,494 Thread-8 udi_interface ERROR udi_interface:write: :
2023-11-17 19:14:57,495 Thread-8 udi_interface ERROR udi_interface:write: 'Controller' object has no attribute 'exit'
Edited by Jimbo.Automates
Ended up deleting then reinstalling elk nodeserver and all is well.
Must have been something that I did :).
Thanks again for the great product and for trying to help.
      37k
      371.4k
