'Client was stopped' error
Hello, every few days the node server semi-crashes, semi as in it is non-functional, but it is still running.  Here is the log:
2023-12-04 03:02:29,708 read_thread sleekxmpp.xmlstream.xmlstream ERROR    xmlstream:_process: Error reading from XML stream.
2023-12-04 03:02:47,204 Command    sleekxmpp.xmlstream.handler.waiter WARNING  waiter:wait: Timed out waiting for IqWait_d0d0f51b-e409-4549-a109-816ac91d8f77-11
2023-12-04 03:02:47,205 Command    pyharmony.client   INFO     client:get_current_activity: XMPP timeout, reattempting
2023-12-04 03:03:17,209 Command    sleekxmpp.xmlstream.handler.waiter WARNING  waiter:wait: Timed out waiting for IqWait_d0d0f51b-e409-4549-a109-816ac91d8f77-11
2023-12-04 03:03:17,209 Command    udi_interface      ERROR    udi_interface:write: --- Logging error ---
2023-12-04 03:03:17,212 Command    udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2023-12-04 03:03:17,212 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/pyharmony/pyharmony/client.py", line 78, in get_current_activity
    result = iq_cmd.send(block=True)
2023-12-04 03:03:17,212 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/.local/lib/python3.9/site-packages/sleekxmpp/stanza/iq.py", line 233, in send
    raise IqTimeout(self)
2023-12-04 03:03:17,212 Command    udi_interface      ERROR    udi_interface:write: sleekxmpp.exceptions.IqTimeout: <iq id="d0d0f51b-e409-4549-a109-816ac91d8f77-11" type="get"><oa xmlns="connect.logitech.com" mime="vnd.logitech.harmony/vnd.logitech.harmony.engine?getCurrentActivity" /></iq>
2023-12-04 03:03:17,212 Command    udi_interface      ERROR    udi_interface:write: During handling of the above exception, another exception occurred:
2023-12-04 03:03:17,213 Command    udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2023-12-04 03:03:17,213 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/nodes/Hub.py", line 252, in _get_current_activity
    ca = self.client.get_current_activity()
2023-12-04 03:03:17,213 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/pyharmony/pyharmony/client.py", line 81, in get_current_activity
2023-12-04 03:03:17,213 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/.local/lib/python3.9/site-packages/sleekxmpp/stanza/iq.py", line 233, in send
2023-12-04 03:03:17,213 Command    udi_interface      ERROR    udi_interface:write: sleekxmpp.exceptions.IqTimeout: <iq id="d0d0f51b-e409-4549-a109-816ac91d8f77-11" type="get"><oa xmlns="connect.logitech.com" mime="vnd.logitech.harmony/vnd.logitech.harmony.engine?getCurrentActivity" /></iq>
2023-12-04 03:03:17,213 Command    udi_interface      ERROR    udi_interface:write: During handling of the above exception, another exception occurred:
2023-12-04 03:03:17,213 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/logging/__init__.py", line 1083, in emit
    msg = self.format(record)
2023-12-04 03:03:17,214 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/logging/__init__.py", line 927, in format
    return fmt.format(record)
2023-12-04 03:03:17,214 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/logging/__init__.py", line 663, in format
    record.message = record.getMessage()
2023-12-04 03:03:17,214 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/logging/__init__.py", line 367, in getMessage
    msg = msg % self.args
2023-12-04 03:03:17,214 Command    udi_interface      ERROR    udi_interface:write: TypeError: not all arguments converted during string formatting
2023-12-04 03:03:17,214 Command    udi_interface      ERROR    udi_interface:write: Call stack:
2023-12-04 03:03:17,216 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 937, in _bootstrap
    self._bootstrap_inner()
2023-12-04 03:03:17,216 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner
    self.run()
2023-12-04 03:03:17,216 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run
    self._target(*self._args, **self._kwargs)
2023-12-04 03:03:17,216 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 859, in _parseInput
    self._handleInput(key, input[key], None)
2023-12-04 03:03:17,216 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 1007, in _handleInput
    self.nodes_internal[item['address']].query()
2023-12-04 03:03:17,217 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/nodes/Controller.py", line 210, in query
    self.poly.getNode(node).query()
2023-12-04 03:03:17,217 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/nodes/Hub.py", line 94, in query
    self._get_current_activity()
2023-12-04 03:03:17,217 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/nodes/Hub.py", line 254, in _get_current_activity
    LOGGER.error('client.get_current_activity timeout',False)
2023-12-04 03:03:17,217 Command    udi_interface      ERROR    udi_interface:write: Message: 'client.get_current_activity timeout'
Arguments: (False,)
2023-12-04 03:03:17,217 Command    udi_interface      INFO     Hub:_set_st: setDriver(ST,0)
2023-12-04 03:03:17,264 MQTT       udi_interface.interface INFO     interface:_message: Successfully set h9bfc75ec675d0 :: ST to 0 UOM 2
2023-12-04 03:03:17,730 Command    udi_interface.node INFO     node:reportDrivers: Updating All Drivers to ISY for Living Room(h9bfc75ec675d0)
2023-12-04 03:03:17,731 Command    udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:03:17,731 Command    udi_interface      INFO     Hub:_set_st: setDriver(ST,1)
2023-12-04 03:03:17,731 Command    udi_interface      ERROR    udi_interface:write: --- Logging error ---
2023-12-04 03:03:17,731 Command    udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2023-12-04 03:03:17,732 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/nodes/Hub.py", line 252, in _get_current_activity
2023-12-04 03:03:17,732 Command    udi_interface      ERROR    udi_interface:write: AttributeError: 'NoneType' object has no attribute 'get_current_activity'
2023-12-04 03:03:17,732 Command    udi_interface      ERROR    udi_interface:write: During handling of the above exception, another exception occurred:
2023-12-04 03:03:17,732 Command    udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2023-12-04 03:03:17,732 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/logging/__init__.py", line 1083, in emit
2023-12-04 03:03:17,732 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/logging/__init__.py", line 927, in format
2023-12-04 03:03:17,732 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/logging/__init__.py", line 663, in format
2023-12-04 03:03:17,733 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/logging/__init__.py", line 367, in getMessage
2023-12-04 03:03:17,733 Command    udi_interface      ERROR    udi_interface:write: TypeError: not all arguments converted during string formatting
2023-12-04 03:03:17,733 Command    udi_interface      ERROR    udi_interface:write: Call stack:
2023-12-04 03:03:17,733 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 937, in _bootstrap
2023-12-04 03:03:17,733 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner
    self.run()
2023-12-04 03:03:17,733 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run
2023-12-04 03:03:17,733 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 859, in _parseInput
2023-12-04 03:03:17,734 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 1007, in _handleInput
2023-12-04 03:03:17,734 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/nodes/Hub.py", line 94, in query
2023-12-04 03:03:17,734 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026524_14/nodes/Hub.py", line 258, in _get_current_activity
    LOGGER.error('client.get_current_activity failed',True)
2023-12-04 03:03:17,734 Command    udi_interface      ERROR    udi_interface:write: Message: 'client.get_current_activity failed'
Arguments: (True,)
2023-12-04 03:04:21,912 Thread-1049 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:04:21,913 Thread-1049 udi_interface      INFO     Hub:_set_st: setDriver(ST,1)
2023-12-04 03:04:21,913 Thread-1049 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 03:09:21,913 Thread-1055 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:09:21,913 Thread-1055 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 03:14:21,919 Thread-1061 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:14:21,919 Thread-1061 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 03:19:21,935 Thread-1067 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:19:21,935 Thread-1067 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 03:24:21,936 Thread-1073 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:24:21,936 Thread-1073 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 03:29:21,941 Thread-1079 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:29:21,941 Thread-1079 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 03:34:21,942 Thread-1085 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:34:21,942 Thread-1085 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 03:39:21,946 Thread-1091 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:39:21,946 Thread-1091 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 03:44:21,955 Thread-1097 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:44:21,955 Thread-1097 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 03:49:21,956 Thread-1103 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:49:21,956 Thread-1103 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 03:54:21,957 Thread-1109 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:54:21,957 Thread-1109 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 03:59:21,960 Thread-1115 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 03:59:21,961 Thread-1115 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 04:04:21,967 Thread-1121 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:04:21,968 Thread-1121 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 04:09:21,969 Thread-1127 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:09:21,970 Thread-1127 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 04:14:21,970 Thread-1133 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:14:21,971 Thread-1133 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 04:19:21,981 Thread-1139 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:19:21,981 Thread-1139 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 04:24:21,983 Thread-1145 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:24:21,983 Thread-1145 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 04:29:21,992 Thread-1151 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:29:21,992 Thread-1151 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 04:34:22,001 Thread-1157 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:34:22,001 Thread-1157 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 04:39:22,017 Thread-1163 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:39:22,018 Thread-1163 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 04:44:22,024 Thread-1169 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:44:22,024 Thread-1169 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 04:49:22,031 Thread-1175 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:49:22,032 Thread-1175 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 04:54:22,033 Thread-1181 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:54:22,033 Thread-1181 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 04:59:22,035 Thread-1187 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 04:59:22,036 Thread-1187 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 05:04:22,044 Thread-1193 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 05:04:22,044 Thread-1193 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 05:09:22,061 Thread-1199 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 05:09:22,062 Thread-1199 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 05:14:22,066 Thread-1205 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 05:14:22,066 Thread-1205 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 05:18:29,475 Command    udi_interface      ERROR    Hub:start_activity: No Client
2023-12-04 05:19:22,076 Thread-1211 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 05:19:22,076 Thread-1211 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 05:20:23,055 Command    udi_interface      ERROR    Hub:start_activity: No Client
2023-12-04 05:24:22,078 Thread-1217 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 05:24:22,078 Thread-1217 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 05:29:22,081 Thread-1223 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 05:29:22,081 Thread-1223 udi_interface      INFO     Controller:heartbeat: hb=0
2023-12-04 05:34:22,096 Thread-1229 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 05:34:22,096 Thread-1229 udi_interface      INFO     Controller:heartbeat: hb=1
2023-12-04 05:39:22,104 Thread-1235 udi_interface      INFO     Hub:check_client: Client was stopped. clientNone
2023-12-04 05:39:22,105 Thread-1235 udi_interface      INFO     Controller:heartbeat: hb=0
It just continues to repeat the 'client was stopped' message until I eventually notice and restart the nodeserver.
Solved by Jimbo.Automates
Yes I do.
Edit:  Also, it's interesting that it seems to happen after 3AM, when the query runs.  Not sure I need that anymore, maybe I'll disable it and see what happens...
Edited by skunkiechris
This is an internal error in the harmony client module I use, which is not really supported anymore, but I'll try to take a look and see if there is a way I can detect and restart when this happens.  It'll be difficult since it's not repeatable, and I've never seen or heard if this before.  Issue created https://github.com/UniversalDevicesInc-PG3/udi-harmony-poly/issues/38
Thanks so much!!!
11 hours ago, Jimbo.Automates said:
@skunkiechris Release 3.0.9 has an attempt to fix this, please update and let me know if you see it again.
Awesome, I've updated, will let you know, thank you so much!!!
@Jimbo.Automates  Hmmmm, it doesn't seem to work after the update.  My hubs.json is still in the config director, I changed nothing....but it doesn't see the Harmony at all.
2023-12-19 15:35:26,909 MainThread udi_interface      INFO     polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-12-19 15:35:26,909 MainThread udi_interface      INFO     __init__:<module>: UDI interface initializing
2023-12-19 15:35:26,909 MainThread udi_interface      INFO     __init__:<module>: User=0021b9026524_14
2023-12-19 15:35:26,910 MainThread udi_interface      INFO     __init__:<module>: Home=/var/polyglot/pg3/ns/0021b9026524_14
2023-12-19 15:35:26,910 MainThread udi_interface      INFO     __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b9026524_14
2023-12-19 15:35:26,910 MainThread udi_interface      INFO     __init__:<module>: PG3INIT=<redacted>
2023-12-19 15:35:26,910 MainThread udi_interface      INFO     __init__:<module>: Loading interface module
2023-12-19 15:35:26,955 MainThread udi_interface      INFO     interface:<module>: Loading MQTT module
2023-12-19 15:35:27,483 MainThread udi_interface      INFO     interface:<module>: MQTT module loaded
2023-12-19 15:35:27,712 MainThread udi_interface      INFO     __init__:<module>: Loading udi_interface module
2023-12-19 15:35:27,713 MainThread udi_interface      INFO     __init__:<module>: Loading node module
2023-12-19 15:35:27,713 MainThread udi_interface      INFO     __init__:<module>: Loading custom module
2023-12-19 15:35:27,713 MainThread udi_interface      INFO     __init__:<module>: Loading isy module
2023-12-19 15:35:27,713 MainThread udi_interface      INFO     __init__:<module>: UDI interface initialized
2023-12-19 15:35:27,714 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.6 Starting...
2023-12-19 15:35:27,771 MainThread udi_interface.interface INFO     interface:__init__: Initialization received from Polyglot V3 3.2.16  [ISY: 5.7.1, Slot: 14]
2023-12-19 15:35:27,771 MainThread udi_interface.interface INFO     interface:__init__: Connect: Network Interface: {'addr': '172.26.18.3', 'netmask': '255.255.255.0', 'broadcast': '172.26.18.255'}
2023-12-19 15:35:27,772 Interface  udi_interface.interface INFO     interface:_startMqtt: Connecting to MQTT... localhost:8883
2023-12-19 15:35:27,772 MainThread udi_interface.interface INFO     interface:updateProfile: Sending Install Profile command to Polyglot.
2023-12-19 15:35:27,772 Interface  udi_interface.interface INFO     interface:_startMqtt: Using SSL cert: 0021b9026524_14.cert key: 0021b9026524_14.key ca: /usr/local/etc/ssl/certs/ud.ca.cert
2023-12-19 15:35:27,773 MainThread udi_interface      INFO     Controller:__init__: HarmonyController: Initializing
2023-12-19 15:35:27,773 MainThread udi_interface.interface WARNING  interface:db_getNodeDrivers: harmonyctrl not found in database.
2023-12-19 15:35:27,773 MainThread udi_interface.interface INFO     interface:addNode: Adding node HarmonyHub Controller(harmonyctrl) [None]
2023-12-19 15:35:27,773 MainThread udi_interface.interface INFO     interface:setController: Using node "harmonyctrl", driver "ST" for connection status.
2023-12-19 15:35:27,819 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Connected with result code 0 (Success)
2023-12-19 15:35:27,820 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:24_14 -  MID: 2 Result: 0
2023-12-19 15:35:27,861 MQTT       udi_interface.interface INFO     interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,)
2023-12-19 15:35:27,943 MQTT       udi_interface.interface INFO     interface:_message: custom data response {'customparamsdoc': ''}
2023-12-19 15:35:27,943 MQTT       udi_interface.interface INFO     interface:_message: Successfully set key = customparamsdoc
2023-12-19 15:35:28,115 Thread-5   udi_interface.interface WARNING  interface:checkProfile: check_profile: Force is enabled.
Seems like maybe that warning line is something?  Thanks...
Okay, so, I did absolutely nothing whatsoever. When I left it the main device in eisy was borked, and all my programs had not specified, no nodes in polyglot.  Went away, made dinner, turned on the TV, and everything reacted correctly.  Looked at eisy/polyglot, and things are normal. So, I guess disregard the above!
That's great, but odd. Anything new in the log?
Sent from my Pixel 8 Pro using Tapatalk
Hmmm....I hadn't actually grabbed the log yet when it started working yesterday.  I just went to look now and I only see a log from today in the logs directory.  I guess logs are deleted on a daily basis?  :(
Hmmm....I hadn't actually grabbed the log yet when it started working yesterday.  I just went to look now and I only see a log from today in the logs directory.  I guess logs are deleted on a daily basis?  [emoji20]
Yes, they are rolled each day at midnight. They still exist, but can't see them in PG3 UI.
  • 1 month later...
Haven't had the client stopped error a single time since the change....seems to be working!!! Thanks again!!
