RING Spotlight Cam 2nd Battery Life
Can the 2nd battery life be added for the device?
I believe the batteries are in parallel, If that's the case, then when the battery level is low it means both batteries need to be replaced or recharged
Edited by Techman
Only 1 battery requires a charge when low.  Always just removed the low battery for recharge while 2nd continues  to power device.
