Nodes & Controller questions
OK, I think we're on the home stretch in getting to really understand the Notification Node Server (or is the preferred term Plugin now?).
Screenshot1 show nodes 2 and 3 that I have defined within the Notification NS/plugin.  Node is the ISYPortal Service Node I created by filling in my API key from UD Mobile.  It shows up in the Admin Console - see screenshot2. It, and the UD Mobile node are listed under the Notification Controller Device.
Q1: Is the ISYPortal Service Node even necessary? Or can I just use the UD Mobile node and custom messages from Configuration/Emails/Notficiations/Customizations?  If it is necessary, where/how is it used?
Q2: From screenshot2, the Device is set to group Kent which is great. The Message is 0 because I don't have any predefined messages from the Configuration tab of the Notification plugin.  (I had a couple test messages there but deleted them because the instructions say that is not the best way to do that anymore.). I can't see any reason I'd send a message from this screen with the "Send Message" button at the bottom.  Is that correct?  Is there a reason other than testing that I use it here?
Q3: When I press the "System Custom Content" button, no message is generated. But if I push the "Send Sys Custom With Params" button, I get the UD Test Message showing up under Notifications in UD Mobile. Why does "System Custom Content" not send a message?
Let's start with these.  I'm trying to gather enough helpful info to put in a "Notifications for Dummies" kind of doc to share. Thanks!
Q1: ISYPortal node is not necessary, that was implemented before UDM node was created.  But, ISYPortal does have more functionality, which is not always needed.  UDM mode was simplified.
Q2: It is not necessary now that custom content is available, unless you prefer that for short simple messages.
Q3: When you press the "System Custom Content" button it sets the message that will be used if you click the "Send Sys Custom" at the bottom.
@Jimbo.Automates Thanks for the responses! Is the additional ISYPortal functionality what is described as "REST Interface"?  I really want to learn more about how to use that.
Also, what is the best resource you know of to use the pushover.net service with your Notification plugin?
Thanks!!
@Jimbo.Automates can I make a suggestion that features that are really no longer needed (but may still be used) be moved to a section in your readme me file called OLD FEATURES or something like that? It would help new users like myself sort through what I really need to read and focus on.  This is a nice plugin but I'm still trying to sort out all the pieces.  If there were some I knew were old, out dated features, I could skip them entirely.  Just a thought.
