ratgdo Experiences
Thoughts of something like this..
Just received the v2.53i as well an looking into this converter that has a micro usb on the end so no need to solder anything... wire up to the 8500w battery similar to how ChuckBuilds did and then just plug the micro usb into the v2.53i...
Also found a straight version micro usb vs. 90 degree too... trying to determine if one is better than other based on reviews.... there are a ton on Amazon.. curious what others have had success with brand / model wise since most probably come from same source mostly..
In the end, I went with simple solution. It’s a USB wart plugged into AC outlet on garage ceiling with its wire zip tied to power cord down to GDO. ratgdo is in an enclosure I 3D printed held in place with magnets. You can make it out in front of white wiring.
