Access Points Needed Anymore?
Almost all dual band devices. Have a built in communications test (4 tap test for many or flow chart to follow). You can try the test to supplement testing the system with them unplugged.
If the revision is any of the 1 series. They are on the transformer style main board with a daughter board. The revision 2 are on the same main board as the 2413 PLM. With the same capacitor issues as the PLM. Revision number may effect the decision.  I have a pair of 1.6 in use for many years. Replacing a pair of revision 2 that had failed power supplies.
Edited by Brian H
