NOAA Weather Updates
The plugin is not receiving updates.  Deleted and reinstalled.  This plugin has been working correctly since installed in April.
debug.log
Edited by TUhl01
11 hours ago, bpwwer said:
Set the log level to debug and see what shows up.  The above log doesn't show any errors.
Debug log attached.
debug.log
That log shows this:
'Connection aborted.', RemoteDisconnected('Remote end closed connection without response')
Which is saying the NOAA server simply dropped the network connection without sending any data.
However, it still doesn't look like you debug log level enabled as there's no debug log entries.
Seems to be working.  I did notice that the short poll was set at 3600 and long 600. These were the values when reinstalled and before as I recall.  Please check if these are the values that are in the download plugin. Changed short to 900 and long to 1800. Not sure if this caused the problem or a NOAA issue.
