TUhl01 Posted December 30, 2023 Posted December 30, 2023 (edited) The plugin is not receiving updates. Deleted and reinstalled. This plugin has been working correctly since installed in April. debug.logFetching info... Edited December 30, 2023 by TUhl01
bpwwer Posted December 31, 2023 Posted December 31, 2023 Set the log level to debug and see what shows up. The above log doesn't show any errors.
TUhl01 Posted December 31, 2023 Author Posted December 31, 2023 On 12/31/2023 at 3:39 AM, bpwwer said: Set the log level to debug and see what shows up. The above log doesn't show any errors. Expand Debug log attached. debug.logFetching info...
bpwwer Posted January 1, 2024 Posted January 1, 2024 That log shows this: 'Connection aborted.', RemoteDisconnected('Remote end closed connection without response') Which is saying the NOAA server simply dropped the network connection without sending any data. However, it still doesn't look like you debug log level enabled as there's no debug log entries.
TUhl01 Posted January 3, 2024 Author Posted January 3, 2024 On 1/1/2024 at 7:14 PM, bpwwer said: That log shows this: 'Connection aborted.', RemoteDisconnected('Remote end closed connection without response') Which is saying the NOAA server simply dropped the network connection without sending any data. However, it still doesn't look like you debug log level enabled as there's no debug log entries. Expand Seems to be working. I did notice that the short poll was set at 3600 and long 600. These were the values when reinstalled and before as I recall. Please check if these are the values that are in the download plugin. Changed short to 900 and long to 1800. Not sure if this caused the problem or a NOAA issue.
