Insteon Code Abbreviations?
I'd like to know what the following "INSTEON Level 2 Codes" infer.
INST-ACK = Instruction-Acknowledge?
INST-SRX = Instruction-Standard Receive Communication?
INST-ERX = Instruction-Extended Receive Communication?
Just Curious...
Jon
Hi Jon,
You have it figured out.
There is a Wiki page: Using the Event Viewer
INST-ACK The PLM responded to a command sent by ISY (usually an echo). i2 ACKs are longer (23 bytes).
INST-SRX The receiving device has either responded to a command from ISY or is sending an event. This is the standard length message (i1).
INST-ERX Like INST-SRX, but extended length and returned by i2 devices.
Rand
Just Curious...
Jon
Hi Jon,
Thanks Rand...
I had read the Wiki but it doesn't explain the meaning of the abbreviations as it does with the "INSTEON Action Codes"
DON = Device On
DOF= Device Off
DFON=Device Fast On
DFOF =Device Fast Off
BMAN = Begin Manual Change
SMAN = Stop Manual Change
OL = On-Level
RR = Ramp-Rate
ST= Status
If I managed somehow to guess what they mean then WOO HOO :D
