Sonoff/Tasmota sensor data not populating after upgrading MQTT NS to 0.0.34
I had some messy eisy issues and I am hoping someone can help with the last broken item.
Data from my Sonoff/Tasmota AM2301 and DS18B20 sensors is not populating in the mqtt NS or Eisy UI after things went wonky.
My stability problems started while adding a new temperature sensor to my mqtt devices.yaml file and I am still unsure why.  Sonoff devices and all zwave nodes became unresponsive, and all my Programs disappeared from the UI.  After a reboot the eisy was in an initializing system loop and would not recover.  UI stability came back after I upgraded packages to 5.80 via the UI and rebooted.  I also upgraded the mqtt NS to 0.0.34 which defaulted the port back to 1884 when I am running port 1883 on a standalone broker.  After a bunch of needless troubleshooting I discovered the port issue and thought I was good when the Sonoff switch devices started working properly.  However, the sensor values are still not populating in the NS or UI, yet I see MQTT messages with correct sensor data in the debug log.  Lastly, values look are fine in the tasmota UI as well as Home assitant.
I deleted the nodes in the NS and UI, restarted the MQTT NS and UI but no change.
I deleted and reinstalled the 0.0.34 NS but no change
Sorry for the all detailed drama, does anyone have any ideas why sensor data is not populating?
Thank you in advance.
Alan
Debug Log
2024-01-09 00:00:49,042 Thread-5   udi_interface      DEBUG    mqtt-poly:_on_message: Received _on_message {"Time":"2024-01-09T06:00:48","AM2301":{"Temperature":37.8,"Humidity":67.0,"DewPoint":27.8},"TempUnit":"F"} from tele/attictemp/SENSOR
2024-01-09 00:00:49,043 Thread-5   udi_interface      INFO     mqtt-poly:_on_message: _OAM: AM2301
2024-01-09 00:00:49,043 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA1: tele/attictemp/SENSOR  AM2301
2024-01-09 00:00:49,043 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: DLT: [{'id': 'shellytest1', 'type': 'switch', 'status_topic': 'stat/shellytest1/POWER', 'cmd_topic': 'cmnd/shellytest1/power'}, {'id': 'sonoff1', 'type': 'switch', 'status_topic': 'stat/sonoff1/POWER', 'cmd_topic': 'cmnd/sonoff1/power'}, {'id': 'basementlight', 'type': 'switch', 'status_topic': 'stat/basementlight/POWER', 'cmd_topic': 'cmnd/basementlight/power'}, {'id': 'benchrgbw', 'type': 'switch', 'status_topic': 'stat/benchrgbw/POWER', 'cmd_topic': 'cmnd/benchrgbw/power'}, {'id': 'sensornode1', 'type': 'sensor', 'status_topic': 'tele/sonoff2/SENSOR', 'cmd_topic': 'cmnd/sensor2/POWER'}, {'id': 'outsidetemp', 'type': 'Temp', 'status_topic': 'tele/outsidetemp/SENSOR', 'cmd_topic': 'cmnd/outsidetemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/outsidetemp/STATUS10'}, {'id': 'outsideswitch', 'type': 'switch', 'status_topic': 'stat/outsidetemp/POWER', 'cmd_topic': 'cmnd/outsidetemp/power'}, {'id': 'masterbathfan', 'type': 'switch', 'status_topic': 'stat/masbathfan/POWER', 'cmd_topic': 'cmnd/masbathfan/power'}, {'id': 'masterbathtemp', 'type': 'TempHumid', 'status_topic': 'tele/masterbathtemp/SENSOR', 'cmd_topic': 'cmnd/masterbathtemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/masterbathtemp/STATUS10'}, {'id': 'shedenclosuretemp', 'type': 'TempHumid', 'status_topic': 'tele/shedenclosuretemp/SENSOR', 'cmd_topic': 'cmnd/shedenclosuretemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/shedenclosuretemp/STATUS10'}, {'id': 'shedenclosuretempswitch', 'type': 'switch', 'status_topic': 'stat/shedenclosuretemp/POWER', 'cmd_topic': 'cmnd/shedenclosuretemp/power'}, {'id': 'shopaircomp', 'type': 'switch', 'status_topic': 'stat/shopaircomp/POWER', 'cmd_topic': 'cmnd/shopaircomp/power'}, {'id': 'attictemp', 'type': 'TempHumid', 'status_topic': 'tele/attictemp/SENSOR', 'cmd_topic': 'cmnd/attictemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/attictemp/STATUS10'}, {'id': 'shellybench', 'type': 'switch', 'status_topic': 'shellies/shellyrgbw/color/0/status', 'cmd_topic': 'shellies/shellyrgbw/color/0/power'}, {'id': 'shopaircleaner', 'type': 'switch', 'status_topic': 'stat/shopaircleaner/POWER', 'cmd_topic': 'cmnd/shopaircleaner/power'}, {'id': 'diningroomoutlet', 'type': 'switch', 'status_topic': 'stat/diningroomoutlet/POWER', 'cmd_topic': 'cmnd/diningroomoutlet/power'}, {'id': 'mainbathlights', 'type': 'switch', 'status_topic': 'stat/mainbathlights/POWER', 'cmd_topic': 'cmnd/mainbathlights/power'}, {'id': 'DiningDivider', 'type': 'switch', 'status_topic': 'stat/diningdivider/POWER', 'cmd_topic': 'cmnd/diningdivider/power'}, {'id': 'diningwindows', 'type': 'switch', 'status_topic': 'stat/diningwindows/POWER', 'cmd_topic': 'cmnd/diningwindows/power'}, {'id': 'bedmotionleft', 'type': 'sensor', 'status_topic': 'stat/bedmotionleft/SENSOR', 'cmd_topic': 'cmnd/bedmotionleft/power'}, {'id': 'shedenclosureheater', 'type': 'switch', 'status_topic': 'stat/shedenclosureheater/POWER', 'cmd_topic': 'cmnd/shedenclosureheater/power'}, {'id': 'garageenclosureheater', 'type': 'switch', 'status_topic': 'stat/garageenclosureheater/POWER', 'cmd_topic': 'cmnd/garageenclosureheater/power'}, {'id': 'shedtemp', 'type': 'TempHumid', 'status_topic': 'tele/shedtemp/SENSOR', 'cmd_topic': 'cmnd/shedtemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/shedtemp/STATUS10'}, {'id': 'garagetempnew', 'type': 'TempHumid', 'status_topic': 'tele/garagetempnew/SENSOR', 'cmd_topic': 'cmnd/garagetempnew/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/garagetempnew/STATUS10'}]
2024-01-09 00:00:49,043 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'shellytest1', 'type': 'switch', 'status_topic': 'stat/shellytest1/POWER', 'cmd_topic': 'cmnd/shellytest1/power'}
2024-01-09 00:00:49,043 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'sonoff1', 'type': 'switch', 'status_topic': 'stat/sonoff1/POWER', 'cmd_topic': 'cmnd/sonoff1/power'}
2024-01-09 00:00:49,043 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'basementlight', 'type': 'switch', 'status_topic': 'stat/basementlight/POWER', 'cmd_topic': 'cmnd/basementlight/power'}
2024-01-09 00:00:49,043 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'benchrgbw', 'type': 'switch', 'status_topic': 'stat/benchrgbw/POWER', 'cmd_topic': 'cmnd/benchrgbw/power'}
2024-01-09 00:00:49,044 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'sensornode1', 'type': 'sensor', 'status_topic': 'tele/sonoff2/SENSOR', 'cmd_topic': 'cmnd/sensor2/POWER'}
2024-01-09 00:00:49,044 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'outsidetemp', 'type': 'Temp', 'status_topic': 'tele/outsidetemp/SENSOR', 'cmd_topic': 'cmnd/outsidetemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/outsidetemp/STATUS10'}
2024-01-09 00:00:49,044 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'outsideswitch', 'type': 'switch', 'status_topic': 'stat/outsidetemp/POWER', 'cmd_topic': 'cmnd/outsidetemp/power'}
2024-01-09 00:00:49,044 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'masterbathfan', 'type': 'switch', 'status_topic': 'stat/masbathfan/POWER', 'cmd_topic': 'cmnd/masbathfan/power'}
2024-01-09 00:00:49,044 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'masterbathtemp', 'type': 'TempHumid', 'status_topic': 'tele/masterbathtemp/SENSOR', 'cmd_topic': 'cmnd/masterbathtemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/masterbathtemp/STATUS10'}
2024-01-09 00:00:49,044 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'shedenclosuretemp', 'type': 'TempHumid', 'status_topic': 'tele/shedenclosuretemp/SENSOR', 'cmd_topic': 'cmnd/shedenclosuretemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/shedenclosuretemp/STATUS10'}
2024-01-09 00:00:49,044 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'shedenclosuretempswitch', 'type': 'switch', 'status_topic': 'stat/shedenclosuretemp/POWER', 'cmd_topic': 'cmnd/shedenclosuretemp/power'}
2024-01-09 00:00:49,044 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'shopaircomp', 'type': 'switch', 'status_topic': 'stat/shopaircomp/POWER', 'cmd_topic': 'cmnd/shopaircomp/power'}
2024-01-09 00:00:49,044 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'attictemp', 'type': 'TempHumid', 'status_topic': 'tele/attictemp/SENSOR', 'cmd_topic': 'cmnd/attictemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/attictemp/STATUS10'}
2024-01-09 00:00:49,045 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'shellybench', 'type': 'switch', 'status_topic': 'shellies/shellyrgbw/color/0/status', 'cmd_topic': 'shellies/shellyrgbw/color/0/power'}
2024-01-09 00:00:49,045 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'shopaircleaner', 'type': 'switch', 'status_topic': 'stat/shopaircleaner/POWER', 'cmd_topic': 'cmnd/shopaircleaner/power'}
2024-01-09 00:00:49,045 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'diningroomoutlet', 'type': 'switch', 'status_topic': 'stat/diningroomoutlet/POWER', 'cmd_topic': 'cmnd/diningroomoutlet/power'}
2024-01-09 00:00:49,045 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'mainbathlights', 'type': 'switch', 'status_topic': 'stat/mainbathlights/POWER', 'cmd_topic': 'cmnd/mainbathlights/power'}
2024-01-09 00:00:49,045 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'DiningDivider', 'type': 'switch', 'status_topic': 'stat/diningdivider/POWER', 'cmd_topic': 'cmnd/diningdivider/power'}
2024-01-09 00:00:49,045 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'diningwindows', 'type': 'switch', 'status_topic': 'stat/diningwindows/POWER', 'cmd_topic': 'cmnd/diningwindows/power'}
2024-01-09 00:00:49,045 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'bedmotionleft', 'type': 'sensor', 'status_topic': 'stat/bedmotionleft/SENSOR', 'cmd_topic': 'cmnd/bedmotionleft/power'}
2024-01-09 00:00:49,045 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'shedenclosureheater', 'type': 'switch', 'status_topic': 'stat/shedenclosureheater/POWER', 'cmd_topic': 'cmnd/shedenclosureheater/power'}
2024-01-09 00:00:49,045 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'garageenclosureheater', 'type': 'switch', 'status_topic': 'stat/garageenclosureheater/POWER', 'cmd_topic': 'cmnd/garageenclosureheater/power'}
2024-01-09 00:00:49,046 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'shedtemp', 'type': 'TempHumid', 'status_topic': 'tele/shedtemp/SENSOR', 'cmd_topic': 'cmnd/shedtemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/shedtemp/STATUS10'}
2024-01-09 00:00:49,046 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA2: {'id': 'garagetempnew', 'type': 'TempHumid', 'status_topic': 'tele/garagetempnew/SENSOR', 'cmd_topic': 'cmnd/garagetempnew/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/garagetempnew/STATUS10'}
2024-01-09 00:00:49,046 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: NODE_ID2: None
2024-01-09 00:00:49,046 Thread-5   udi_interface      ERROR    mqtt-poly:_on_message: Failed to process message 'NoneType' object has no attribute 'updateInfo'
2024-01-09 00:01:09,895 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
2024-01-09 00:01:09,895 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING shortPoll
2024-01-09 00:02:09,897 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
2024-01-09 00:02:09,897 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING shortPoll
2024-01-09 00:02:55,882 Thread-5   udi_interface      DEBUG    mqtt-poly:_on_message: Received _on_message {"Time":"2024-01-09T06:02:55","AM2301":{"Temperature":35.4,"Humidity":73.2,"DewPoint":27.7},"TempUnit":"F"} from tele/garagetempnew/SENSOR
2024-01-09 00:02:55,883 Thread-5   udi_interface      INFO     mqtt-poly:_on_message: _OAM: AM2301
2024-01-09 00:02:55,883 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: GDA1: tele/garagetempnew/SENSOR  AM2301
2024-01-09 00:02:55,883 Thread-5   udi_interface      DEBUG    mqtt-poly:_get_device_address_from_sensor_id: DLT: [{'id': 'shellytest1', 'type': 'switch', 'status_topic': 'stat/shellytest1/POWER', 'cmd_topic': 'cmnd/shellytest1/power'}, {'id': 'sonoff1', 'type': 'switch', 'status_topic': 'stat/sonoff1/POWER', 'cmd_topic': 'cmnd/sonoff1/power'}, {'id': 'basementlight', 'type': 'switch', 'status_topic': 'stat/basementlight/POWER', 'cmd_topic': 'cmnd/basementlight/power'}, {'id': 'benchrgbw', 'type': 'switch', 'status_topic': 'stat/benchrgbw/POWER', 'cmd_topic': 'cmnd/benchrgbw/power'}, {'id': 'sensornode1', 'type': 'sensor', 'status_topic': 'tele/sonoff2/SENSOR', 'cmd_topic': 'cmnd/sensor2/POWER'}, {'id': 'outsidetemp', 'type': 'Temp', 'status_topic': 'tele/outsidetemp/SENSOR', 'cmd_topic': 'cmnd/outsidetemp/POWER', 'sensor_id': 'SINGLE_SENSOR', 'extra_status_topic': 'stat/outsidetemp/STATUS10'}, {'id': 'outsideswitch', 'type': 'switch', 'status_topic': 'stat/outsidetemp/POWER', 'cmd_topic': 'cmnd/outsidetemp/p
NS Install Log
Installing collected packages: paho-mqtt, setuptools, python-dotenv, pip, markdown2, pyisy, udi_interface
  WARNING: The script dotenv is installed in '/var/polyglot/pg3/ns/0021b9026135_11/.local/bin' which is not on PATH.
  Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
  WARNING: The scripts pip, pip3 and pip3.9 are installed in '/var/polyglot/pg3/ns/0021b9026135_11/.local/bin' which is not on PATH.
  WARNING: The script markdown2 is installed in '/var/polyglot/pg3/ns/0021b9026135_11/.local/bin' which is not on PATH.
Successfully installed markdown2-2.4.12 paho-mqtt-1.6.1 pip-23.2.1 pyisy-2.1.7 python-dotenv-1.0.0 setuptools-65.5.1 udi_interface-3.2.6
devices.yaml
devices:
- id: "shellytest1"
  type: "switch"
  status_topic: "stat/shellytest1/POWER"
  cmd_topic: "cmnd/shellytest1/power"
- id: "sonoff1"
  type: "switch"
  status_topic: "stat/sonoff1/POWER"
  cmd_topic: "cmnd/sonoff1/power"
- id: "basementlight"
  type: "switch"
  status_topic: "stat/basementlight/POWER"
  cmd_topic: "cmnd/basementlight/power"
- id: "benchrgbw"
  type: "switch"
  status_topic: "stat/benchrgbw/POWER"
  cmd_topic: "cmnd/benchrgbw/power"
- id: "sensornode1"
  type: "sensor"
  status_topic: "tele/sonoff2/SENSOR"
  cmd_topic: "cmnd/sensor2/POWER"
- id: "outsidetemp"
  type: "Temp"
  status_topic: "tele/outsidetemp/SENSOR"
  cmd_topic: "cmnd/outsidetemp/POWER"
- id: "outsideswitch"
  type: "switch"
  status_topic: "stat/outsidetemp/POWER"
  cmd_topic: "cmnd/outsidetemp/power"
- id: "masterbathfan"
  type: "switch"
  status_topic: "stat/masbathfan/POWER"
  cmd_topic: "cmnd/masbathfan/power"
- id: "masterbathtemp"
  type: "TempHumid"
  status_topic: "tele/masterbathtemp/SENSOR"
  cmd_topic: "cmnd/masterbathtemp/POWER"
- id: "shedenclosuretemp"
  type: "TempHumid"
  status_topic: "tele/shedenclosuretemp/SENSOR"
  cmd_topic: "cmnd/shedenclosuretemp/POWER"
- id: "shedenclosuretempswitch"
  type: "switch"
  status_topic: "stat/shedenclosuretemp/POWER"
  cmd_topic: "cmnd/shedenclosuretemp/power"
- id: "shopaircomp"
  type: "switch"
  status_topic: "stat/shopaircomp/POWER"
  cmd_topic: "cmnd/shopaircomp/power"
- id: "attictemp"
  type: "TempHumid"
  status_topic: "tele/attictemp/SENSOR"
  cmd_topic: "cmnd/attictemp/POWER"
- id: "shellybench"
  type: "switch"
  status_topic: "shellies/shellyrgbw/color/0/status"
  cmd_topic: "shellies/shellyrgbw/color/0/power"
- id: "shopaircleaner"
  type: "switch"
  status_topic: "stat/shopaircleaner/POWER"
  cmd_topic: "cmnd/shopaircleaner/power"
- id: "diningroomoutlet"
  type: "switch"
  status_topic: "stat/diningroomoutlet/POWER"
  cmd_topic: "cmnd/diningroomoutlet/power"
- id: "mainbathlights"
  type: "switch"
  status_topic: "stat/mainbathlights/POWER"
  cmd_topic: "cmnd/mainbathlights/power"
- id: "DiningDivider"
  type: "switch"
  status_topic: "stat/diningdivider/POWER"
  cmd_topic: "cmnd/diningdivider/power"
- id: "diningwindows"
  type: "switch"
  status_topic: "stat/diningwindows/POWER"
  cmd_topic: "cmnd/diningwindows/power"
- id: "bedmotionleft"
  type: "sensor"
  status_topic: "stat/bedmotionleft/SENSOR"
  cmd_topic: "cmnd/bedmotionleft/power"
- id: "shedenclosureheater"
  type: "switch"
  status_topic: "stat/shedenclosureheater/POWER"
  cmd_topic: "cmnd/shedenclosureheater/power"
- id: "garageenclosureheater"
  type: "switch"
  status_topic: "stat/garageenclosureheater/POWER"
  cmd_topic: "cmnd/garageenclosureheater/power"
- id: "shedtemp"
  type: "TempHumid"
  status_topic: "tele/shedtemp/SENSOR"
  cmd_topic: "cmnd/shedtemp/POWER"
- id: "garagetempnew"
  type: "TempHumid"
  status_topic: "tele/garagetempnew/SENSOR"
  cmd_topic: "cmnd/garagetempnew/POWER"
try re-arranging your list and put all sensors first and all switches last.
also.. with the 5.8 update.. i had to do 2 reboots for the MQTT daemon to start and for all the nodeservers to connect to it.
Thanks for the reply.  I rearranged the device list and no change.  I also rebooted the eisy again, same status.  All MQTT switch devices are working, but the Temp and TempHumid sensor data is displaying zero.
i figured it out... you have to add the "sensor_id" to the sensors...
here is mine...
{"id": "ChickCoop2", "type": "analog", "sensor_id": "Range", "status_topic": "tele/ChickCoop/SENSOR", "cmd_topic": "cmnd/ChickCoop/power"},
{"id": "Temp1", "type": "TempHumid", "sensor_id": "AM2301", "status_topic": "tele/Temp1/SENSOR", "cmd_topic": "cmnd/Temp1/power"},
{"id": "Temp3", "type": "analog", "sensor_id": "Range", "status_topic": "tele/Temp1/SENSOR", "cmd_topic": "cmnd/Temp1/power"},
you can make sure by looking at the console in your device , IE mine show the AM2301 for a temp sensor.
here is my console for one:
22:10:40.274 MQT: tele/StorageTrailer/STATE = {"Time":"2024-01-09T22:10:40","Uptime":"2T22:00:10","UptimeSec":252010,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":1,"SSId":"nsa_surveillance_32","BSSId":"1E:21:B4:49:DF:B2","Channel":10,"Mode":"11n","RSSI":66,"Signal":-67,"LinkCount":2,"Downtime":"0T00:02:47"}}
22:10:40.282 MQT: tele/StorageTrailer/SENSOR = {"Time":"2024-01-09T22:10:40","AM2301":{"Temperature":32.0,"Humidity":73.0,"DewPoint":24.3},"TempUnit":"F"}
this should fix you up...
read the configuration instructions for the node server...it has examples and such..
That did fix me up, thank you!  I did read through the configuration changes, but that is a change in .34 that is easy to miss with my short attention span.
Keep them chickens warm!
Thanks again.
Alan
hahaha.. no worries.. i did the same on the overlook too.
chickens are pampered :)
