How to get beyond "Failure to Set Up" with the Home Assistant UDI plugin?
Go to solution Solved by shbatm,
Posted (edited)
I have installed Home Assistant on a spare NUC and have just begun to learn HA in order to connect to sensors not supported in Polisy. I and am hoping to access my UDI Polisy v5.8 system via Home Assistant to make it all run seamlessly. (LOL)
I can install the plugin and connect to the Polisy.  I then see the HA query all of my devices but the setup then seems to fail with some missing "available nodes" in Home Assistant. Am I reading this correctly? Any ideas as to how to fix?
Here is my Home Assistant log:
2024-01-18 14:41:29.986 DEBUG (MainThread) [pyisy] ISY Response Received: /config
2024-01-18 14:41:30.020 INFO (MainThread) [pyisy] ISY Loaded Configuration
2024-01-18 14:41:30.022 DEBUG (MainThread) [pyisy] ISY Request: http://192.168.1.72:8080/rest/config
2024-01-18 14:41:30.027 DEBUG (MainThread) [pyisy] ISY Response Received: /config
2024-01-18 14:41:30.050 INFO (MainThread) [pyisy] ISY Loaded Configuration
2024-01-18 14:41:30.050 DEBUG (MainThread) [pyisy] Increasing available simultaneous connections
024-01-18 14:41:32.004 DEBUG (MainThread) [pyisy] Parsing group: S-All Dining Room [13825]
2024-01-18 14:41:32.005 DEBUG (MainThread) [pyisy] Parsing group: S-Dining Room [21083]
2024-01-18 14:41:32.006 DEBUG (MainThread) [pyisy] Parsing group: S-All-Office [338]
2024-01-18 14:41:32.007 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-H Special Lights Status [37129]
2024-01-18 14:41:32.007 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-C Kitchen Status [688]
2024-01-18 14:41:32.008 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-B Guest Rm Status [52360]
2024-01-18 14:41:32.008 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-1 Hall Status [27424]
2024-01-18 14:41:32.008 DEBUG (MainThread) [pyisy] Parsing group: S-KPL-E Office Status [38353]
2024-01-18 14:41:32.009 DEBUG (MainThread) [pyisy] Parsing group: S-Christmas Lights [15887]
2024-01-18 14:41:32.009 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ISY (192.168.1.72) for isy994
Traceback (most recent call last):
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 406, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/isy994/init.py”, line 104, in async_setup_entry
await isy.initialize()
File “/usr/local/lib/python3.11/site-packages/pyisy/isy.py”, line 143, in initialize
self.nodes = Nodes(self, xml=isy_setup_results[2])
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/init.py”, line 127, in init
self.parse(xml)
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/init.py”, line 461, in parse
Group(
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/group.py”, line 57, in init
self._update()
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/group.py”, line 101, in _update
valid_nodes = [
File “/usr/local/lib/python3.11/site-packages/pyisy/nodes/group.py”, line 105, in
self._nodes[node].status is not None
AttributeError: ‘Nodes’ object has no attribute ‘status’
Thanks in advance for any help!
Edited by gviliunas
This looks like something I've seen before that had to do with naming of a node/folder on the ISY side that pyisy didn't like.
Can you please visit http://192.168.1.72:8080/rest/nodes and http://192.168.1.72:8080/rest/status in a browser and send me the files saved as XML and I'll take a look? (assuming that's your Polisy ip from logs above)
Posted (edited)
Your "S-Christmas Lights" scene has a link to your "Leak Sensors" folder, I'm not sure how or if that's intentional, but my guess is that's whats causing it to choke:
<group flag="132" nodeDefId="InsteonDimmer">
  <address>15887</address>
  <name>S-Christmas Lights</name>
  <family>6</family>
  <hint>0.0.0.0</hint>
  <parent type="3">47955</parent>
  <deviceGroup>29</deviceGroup>
  <pnode>15887</pnode>
  <members>
    <link type="0">ZY076_1</link>
    <link type="0">ZY077_1</link>
    <link type="0">37 C7 69 1</link>
    <link type="0">35 53 E5 1</link>
    <link type="16">3D 7A 77 8</link>
    <link type="0">51393</link>
  </members>
</group>
<folder flag="0">
  <address>51393</address>
  <name>Leak Sensors</name>
  <family>13</family>
  <parent type="3">53032</parent>
</folder>
Edited by shbatm
  • Like 2
  • Thanks 1
Thanks @shbatm
That is strange. I deleted the Scene and the folder, restarted IoX and now I was successfully able to install the HA plugin!
Yeah!  Thank You!!!!!
      37.3k
      373.6k
