Yet another programming question
In my theater's equipment room, I have a fan that helps cool the rack. The fan is controlled by a lamplinc. I want the fan to turn on when I turn the theater on and turn off an hour after I turn the theater off. I wrote what I thought would work, and it did until I found a glitch last night. About 30 minutes after I turned off the theater, I turned it back on. What I didn't realize is that because of the wait line in the off program, it was still running too!
So I wrote this instead:
To turn the theater On
IR 'IR_020' is Pressed
Run Program 'Theater OFF' (Else Path)
Set 'Theater / Receptacle / Theater NE' On
Wait 1 second
Set 'Theater / Receptacle / Theater NW' On
Wait 1 second
Set 'Theater / Receptacle / Theater SW' On
Wait 5 seconds
Set 'Theater / Receptacle / Theater SE' On
Set 'Indoor / Thermostats / Theater / HVAC Theater' Mode Cool
Wait 5 seconds
Set 'Indoor / Thermostats / Theater / HVAC Theater' Fan Auto
Wait 5 seconds
Set 'Indoor / Thermostats / Theater / HVAC Theater' 80° (Cool Setpoint)
Wait 2 seconds
Set 'Theater / Equipment Fan' On
Then to turn it Off:
IR 'IR_019' is Pressed
Set 'Indoor / Thermostats / Theater / HVAC Theater' Mode Off
Wait 5 seconds
Wait 5 minutes
Set 'Theater / Receptacle / Theater SW' Off
Wait 5 seconds
Set 'Theater / Receptacle / Theater SE' Off
Wait 5 seconds
Set 'Theater / Receptacle / Theater NW' Off
Wait 5 seconds
Set 'Theater / Receptacle / Theater NE' Off
Wait 1 hour
Set 'Theater / Equipment Fan' Off
Will this logic work?
Hi mitch236,
Why don't you use
Stop Program 'Theater Off'?
-or-
And IR 'IR_020' is Not Pressed
etc.
Rand
