Can Dense Fog Advisory alerts be added
@bpwwerCan Dense Fog Advisory alerts be added to your plug-in? We've had several in the last few days and they aren't being presented in the plug-in.
Thank you!
Solved by bpwwer
It's already there "Dense Fog Advisory".    If it's not working then possibly they've changed the wording so that the parsing is failing.
With the log level at debug, what does the plug-in show when that alert comes in?
The plugin shows nothing other than "None" in the admin console.  I will definitely look at the log next time.
Thank you!
Edited by dbuss
@bpwwerHere's the debug log while we have a Dense Fog Advisory.
2024-02-04 06:03:18,153 Thread-4 udi_interface ERROR noaa:query_alerts: Weather alert update failure
2024-02-04 06:03:18,153 Thread-4 udi_interface ERROR noaa:query_alerts: not well-formed (invalid token): line 1, column 0
That doesn't look like debug information.   The errors indicate that whatever the plug-in got, it wasn't something it recognizes.   I'd need the see the data from the query which it should show if the log level is set to debug.
We aren't under any weather alert at this time.
The first line below indicates an invalid zone. I have been using WIZ048/WIC139, and I have been getting other alerts just fine.
2024-02-04 12:43:48,700 Command udi_interface DEBUG noaa:query_alerts: ? invalid zone
2024-02-04 12:43:48,700 Command udi_interface DEBUG noaa:query_alerts: Parse XML and set drivers
2024-02-04 12:43:48,701 Command udi_interface ERROR noaa:query_alerts: Weather alert update failure
2024-02-04 12:43:48,701 Command udi_interface ERROR noaa:query_alerts: not well-formed (invalid token): line 1, column 0
There should be a debug message before the "? invalid zone" message that shows the actual query request that is being sent.
"? invalid zone" is what's is returned by the query which indicates that the zone is invalid.  WIZ048 is a valid zone and I don't get that error when I query for that zone (but currently, as you said, there are no alerts for that zone).
The query should look like:
https://alerts.weather.gov/cap/wwaatmget.php?x=WIZ048&y=1
2024-02-04 13:13:12,179 Thread-54 udi_interface DEBUG noaa:query_alerts: request = https://alerts.weather.gov/cap/wwaatmget.php?x=WIZ048/WIC139&y=1
16 minutes ago, bpwwer said:
WIZ048 is a valid zone code
WIC139 is a valid county code
WIZ048/WIC139 is not valid
I corrected it and will keep you posted.
Thank you!
Once I corrected the operator error, it worked perfectly.
Thank you, @bpwwer!
