Shower water pump timer
I have a water pump to increase the pressure for the master shower. I only want it to be running when someone is taking a shower. I decided to have the pump come on if two conditions are met. One, the shower light has to be on and two, a motion sensor has to be activated. To that end, I wrote the following program:
Status 'Indoor / Master Bath / Shower' is On
And Status 'Indoor / Master Bath / Shower Sensor / Shower Sensor-Sensor' is On
Set 'Indoor / Master Bath / Water Pump' On
Set 'Indoor / Master Bath / Water Pump' Off
Because my wife tends to leave the lights on, I also wrote the following program to turn off the shower light:
Status 'Indoor / Master Bath / Shower' is not Off
And Status 'Indoor / Master Bath / Shower Sensor / Shower Sensor-Sensor' is not On
Wait 15 minutes
Set 'Indoor / Master Bath / Shower' Off
I set the timeout for the motion sensor to 8.5 minutes. I'm assuming that means that the sensor will send an off signal if no motion is detected in 8.5 minutes which should be sufficient.
Does this look right?
  • 2 months later...
