Read this if you're unable to authenticate
Google will no longer authenticate logins because I've reached unverified maximum. And verifying it is not an easy process.
As a workaround, I'd updated to version 3.0.1 (which is in Beta store for now). You will need to create your own set of API credentials and set client ID and client secret in settings. Also have to add https://my.isy.io/api/cloudlink/redirect to Authorized URLs.
  • 1 month later...
Firstone, could you post instructions for creating the API credentials, setting that up in HolidaysGoogle and adding the URL above to Authorized URLs?  I created a project in Google, enabled calendar API access, created credentials and added them to the configuration but still get the authentication error.  Thanks!
Edited by Mr B
