Can't log into admin console
I am trying to get into the admin console and having problems. This comes after I "cleaned up" some files on my laptop.  I get to this screen and tell it to load admin console. I'm asked to select a file to restore and I get this message. I cannot extract the backup zip to any location. Somehow, I get past that and get the logon screen. It does not recognize my logon credentials and that is where I am stuck.
I can get into thru the ISY Portal and UD Mobile works.
any suggestions for a next step would be appreciated.
Solved by Techman
Thanks for the reply. I did as you said. It did not ask to me download a file. However, it would not accept my logon credentials. Is there a way to reset that?
Ok, that worked sort of.  None of my devices or programs are available. The “restore Backup” option is not available. I cannot rest password either. Thanks for staying with me.
Do you have a current ISY backup. The backup must have been created by clicking on FILE | BACKUP IOX
You can also try closing the admin console, removing power from the ISY, then boot it up.
Edited by Techman
All is good now. I reloaded the admin console, and it worked fine. Admin, admin worked. Password reset worked. All devices and programs are present. Thank you so much for your help.
