Programming in Universal Devices Admin Console
I'm relatively new to UD having begun seriously working in it when Insteon for Hub collapsed  briefly.
I've discovered its elegance and power, but I kind of waded into deep water and got in a little over my head and needed to be bailed out by the Support Staff at UD.
I have an EISY communicating with about 50 nodes, with about 12 Scenes and 6 simple programs. The problem is that my programs stopped working after my system crash because i attempted to write programs on UD Mobile. As I mentioned above, UD Support came to my rescue.
The programs just don't work. They give no error msgs, They just don't work. Even new programs don't work.
I've engaged UD Support on the matter. They are helpful and generous with their time.
Any guidance from anyone would be much appreciated. Thanks in advance.
The best way to get programming help here is to post the program. You can right-click on the program in the admin console, click on copy to clipboard, and then paste it into a post here. Explain what you want the program to do. I'm sure you will get the help you need by doing this.
Outside 1 - [ID 0003][Parent 0001]
        From    Sunset
        To      Sunrise (next day)
        Set 'Outside Lights / Outside Garage Main Entry Lig' On
        Set 'Outside Lights / Outside Garage Main Entry Lig' Off
