Scene Question
can i have a scene where some lights are on and some are off?
if i have a situation where i want to make sure that
lightA goes on
lightB goes off
fan goes on
can that be in a scene?
if not do i just have to program this some how? what is recommended?
I believe this can all be defined as a scene, but must be done through the ISY rather than direct insteon device programming. Using the ISY-99, you simply add the devices you want to the scene, then set the on levels as you desire, including setting it to 0 (or off).
You did not mention how these lights and fans are controlled (switch? keypad? plug-in module? In-line linc?) or which of these, if any, are controllers. If you need further clarification, it may be useful for you to provide such details.
it is a keypad link and want to control from a controlinc
i want some devices on and some off. they are all appliance types so switches. i can't set dim to 0 to have same effect with appliances
As an experiment, I just created a scene including a controller switch and an appliance module. I was able to create an on level of 0 for the appliance module. I have no explanation for why you are unable to set a relay switch in this way. Perhaps different versions of the switch cannot do this. Another possibility is that you have a relatively early version of the ISY software. Both of these theories are just guesses on my part.
ok this works mostly by setting the appliance type modules to 0%
however, the ones that do work, if initially off turn on then off.
then there are those that just turn on and stay on.
any thoughts?
