2.53i online and responding - but door isn't moving.
Hello everyone. I've hit a roadblock and would appreciate some assistance. Here's my setup:
  • Ratgdo Board: 2.53i
  • Opener: Chamberlain RJO70 (side mount)
  • ESPHome version 2024.5.3
  • WiFi coverage in garage is good.
  • Opener button and object sensors are wired into the blue terminal connectors.
  • The r/b/w three-wire connector is wired into the opener.
I managed to flash the board and get the hardware installed, but it's not actually controlling the door. You can see the message below: "The door is not moving." At least I feel like I'm getting closer. :-)
I've got some unrelated issues with my ESPHome/Home Assistant integration, so for now I'm trying to get the Ratgdo to work by controlling it directly.
Can someone tell me if these incomplete packets are normal?
Any thoughts on using the current version of ESPHome, or maybe ditch it for MQTT?
17:24:22	[W]	[ratgdo_secplus1:262]   [17355119] Discard incomplete packet: [3A ...]
17:24:22	[W]	[ratgdo_secplus1:262]	[17355376] Discard incomplete packet: [39 ...]
17:24:23	[W]	[ratgdo_secplus1:262]	[17355621] Discard incomplete packet: [38 ...]
17:24:23	[W]	[ratgdo_secplus1:262]	[17355896] Discard incomplete packet: [3A ...]
17:24:23	[W]	[ratgdo_secplus1:262]	[17356140] Discard incomplete packet: [39 ...]
17:24:23	[W]	[ratgdo_secplus1:262]	[17356399] Discard incomplete packet: [38 ...]
17:24:24	[W]	[ratgdo_secplus1:262]	[17356659] Discard incomplete packet: [3A ...]
17:24:24	[W]	[ratgdo_secplus1:262]	[17356930] Discard incomplete packet: [39 ...]
17:24:24	[W]	[ratgdo_secplus1:262]	[17357192] Discard incomplete packet: [38 ...]
17:24:24	[W]	[ratgdo_secplus1:262]	[17357438] Discard incomplete packet: [3A ...]
17:24:25	[W]	[ratgdo_secplus1:262]	[17357698] Discard incomplete packet: [39 ...]
17:26:28	[W]	[ratgdo_secplus1:262]	[17480591] Discard incomplete packet: [3A ...]
17:26:44	[D]	[button:010]	'Toggle door' Pressed.
17:26:44	[W]	[ratgdo_secplus1:262]	[17497289] Discard incomplete packet: [38 ...]
17:26:54	[D]	[cover:076]	'Door' - Setting
17:26:54	[D]	[cover:080]	  Command: STOP
17:26:54	[W]	[ratgdo:490]	The door is not moving.
17:26:58	[D]	[cover:076]	'Door' - Setting
17:26:58	[D]	[cover:084]	  Position: 100%
17:27:08	[D]	[cover:076]	'Door' - Setting
17:27:08	[D]	[cover:080]	  Command: STOP
17:27:08	[W]	[ratgdo:490]	The door is not moving.
17:27:08	[W]	[ratgdo_secplus1:262]	[17520772] Discard incomplete packet: [38 ...]
17:27:08	[W]	[ratgdo_secplus1:262]	[17521045] Discard incomplete packet: [3A ...]
17:27:08	[W]	[ratgdo_secplus1:262]	[17521289] Discard incomplete packet: [3A ...]
17:27:08	[W]	[ratgdo_secplus1:262]	[17521564] Discard incomplete packet: [3A ...]
17:27:09	[W]	[ratgdo_secplus1:262]	[17521822] Discard incomplete packet: [39 ...]
17:27:09	[W]	[ratgdo_secplus1:262]	[17522070] Discard incomplete packet: [38 ...]
17:27:09	[W]	[ratgdo_secplus1:262]	[17522342] Discard incomplete packet: [3A ...]
17:27:10	[W]	[ratgdo_secplus1:262]	[17522601] Discard incomplete packet: [38 ...]
17:27:10	[W]	[ratgdo_secplus1:262]	[17522859] Discard incomplete packet: [3A ...]
Solved by Goose66
And apologies if I'm in the wrong place! I just realized this is a subforum for Polyglot. Hopefully the fact that I'm troubleshooting Ratgdo directly prevents me from being totally off topic.
