TotalConnect Error - "Discovery failed please check logs for a more detailed error"
Solved by bpwwer
Looks like the library being used by the plug-in has a bug.
Likely, that bug was not something that older versions of Python flagged but newer versions do.  The library was released in Oct. 2020 so It's now 4 years old and has had many, many changes since them.
The TotalConnect plug-in will need to be updated to use a newer version of the library, but there's a high probability that attempting to do so, will cause more issues and require more debugging/updates to the plug-in.
I believe this plug-in is currently unmaintained.  However, I can make a quick attempt to update the library and see what happens.
So now I see the 2.05 version of TotalConnect is PG3 . . . . . and I am still running the TotalConnect version on PG2
Mainly because I have been reluctant to migrate all my PG2 and ISY products over - - - in fear of creating more problems to a fairly stable system on my ISY (hardly nothing is on my POLISY yet)
But I guess unless i perform the migration to Polisy and PG3 I am stuck regarding TotalConnect, is that reasonably accurate?
ahh, I think only the original author has the ability to modify the PG2 version.  I don't have access to the code, but my changes to the PG3 version probably are the same changes needed in the PG2 version.
