Question about Node Def mapping to admin console for Alarm Panel
Hi @Goose66,
I am wanting to add name substitutions for the various panel status values for notifications but I have not been able to locate what the various node definitions map to in the admin console.
For instance, GVO sends its value to what slot in the admin console on the Alarm Panel page?
I have figured out that ST maps to System Alarm State but I could use all the rest.
Any help would be appreciated.
Thank you,
Tim
Edited by TJF1960
Solved by gzahar
ST-ACP-ST-NAME = Alarm Panel Connected
ST-ACP-GV0-NAME = System Alarm State
ST-ACP-GV4-NAME = Bell Trouble
ST-ACP-GV5-NAME = Battery Trouble
ST-ACP-GV6-NAME = AC Trouble
ST-ACP-GV7-NAME = FTC Trouble
ST-ACP-GV8-NAME = Tamper Trouble
ST-ACP-GV9-NAME = Fire Trouble
ST-ACP-GV10-NAME = Zone Fault
ST-ACP-GV11-NAME = Zone Sensor Low Battery
Awesome! Thank you so much @gzahar!
Are these published somewhere that I couldn't find or did you figure it all out?
Thank you again!
-tim
The owner of the plugin has the PG2 version of the code on GitHub. The mappings didn’t change when it was converted to PG3. Also, I believe the A/C normally shows these starting with ST then GVx in numerical order, but there may be exceptions.
