ISY Launcher - "Not Found"
I get the attached error message, two times, when I run the ISY Launcher. Once I dismiss the messages I can login as usual. The UUID and IP address are both correct. Any ideas?!?
Solved by Techman
Did you recently update your controller firmware?
Have you tried clearing your java cache and downloading the IoX launcher again
Done! ...and Done! This worked and I guess should ALWAYS be my first step when issues like this occur. I've only had my install for ~15 years... Finally going to upgrade to EISY soon!
