v3.1.8 in beta
This version adds the control set, and Bonjour for direct Ratgdo integration.
This beta is ALL focused on the garage device & integration to the Ratgdo, something I've been stepping towards with the last two versions.  To remove confusion, there is another Ratgdo garage integration by @Goose66 (called Ratgdo) which is more focused and likely more fully baked ; those not interested in my additional feature set should go there.  As he knows I've been on this path for a bit and have a slightly different take on the feature set due to my use case.  Plus I'm really stubborn and wanted to write it myself.
1. Bonjour discovery for the Ratgdo garage device is added.  Unfortunately, this it can take a bit after start-up & the odd time it seems to take much longer.  Bonjour has been around for a year in the udi_interface, I just recently cracked the code, with some help from @bmercier.   I hope to continue to optimise this.
2. Second, commands can now go directly to the Radgdo and not through variables and/or Home Assistant.  I will NOT be removing the ability to use variables for the garage device as it is meant to be a generic solution for garage users. ( I use them for my Boat house which does not have a Ratgdo ).
3. TODOs, direct Ratgdo status.  Optimise Ratgdo.  Update the docs!
AS ALWAYS FEEDBACK IS WELCOME!
VERSION = '3.1.8'
3.1.8
DONE:
Garage device sends commands directly to Ratgdo through ESPHome RESTapi
Bonjour discovery of Ratgdo garage device
TODO:
Garage device read status directly from Ratgdo through ESPHome RESTapi
Speed up Bonjour discovery optimisation.  Speed & reliability.
3.1.7
Small refactors
redo environment
3.1.6
FIX better solution to markdown2 issue
3.1.5
FIX repair docs due to markdown2 issue
3.1.4
DONE docs updated for garage
3.1.3
DONE: new device 'garage' door (update to/from variables option)
3.1.2
DONE: ISY name changes based on updates to config / YAML / JSON
3.1.1
DONE: YAML file option for configuration
DONE: JSON option for web based configuration
DONE: Discover button to update based on config updates
3.1.0
DONE: move version history out of README to own file
DONE: update docs
3.0.1
DONE fix get value from variable
3.0.0
DONE add control ability to contact device
DONE refactored to modern template
previous updates:
see versionHistory.md
