Documentation link needs to be updated - and a note on elevation
The documentation/"more info" link in the Polyglot 3x store page doesn't work.
"Not found".
https://github.com/UniversalDevicesInc-PG3/udi-sun-poly/master/blob/README.md
If I push that button (MacOS/FirefoxPolyglot V3 via I0X Finder) it takes me to the above link and I get "not found".
 I found the following in a topic on this forum:
https://github.com/UniversalDevicesInc-PG3/udi-sun-poly/blob/master/README.md
This link works.
Took me a minute to spot the difference: the correct link reads blob/master while the incorrect link reads master/blob.
I had some trouble figuring out the format of the parameters. I fiddled around and finally got the format for latitude and longitude, and now I get values.
Still unsure about height. Feet or meters? That's not in the documentation. But at least now I can find the Github repo and read the code to figure it out.
Edit: answer - the poly uses astral.geocoder.
https://astral.readthedocs.io/en/latest/
There's a note in the documentation:
Quote
"Location elevations have been removed from the database. These were added due to a misunderstanding of the affect of elevation on the times of the sun. These are not required for the calculations, only the elevation of the observer above/below the location is needed."
And then I found this about Astral.Observer:
A float that is the elevation in metres above a location, if the nearest obscuring feature is the horizon
Edited by jtara92101
solution for how to set elevation
