Missing element isSceneZones
For some reason my nodes stopped updating. I deleted and reinstalled the plugin which connects just fine to TC2, creates the panel node, but then it gives this error - any idea what is happening?
2024-11-15 07:16:36.910 Thread-2 (parameterHandler) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2024-11-15 07:16:36.910 Thread-2 (parameterHandler) udi_interface ERROR totalconnect-poly:discover: Discovery failed with error Missing element isSceneZones (GetPanelMetaDataAndFullStatusEx_V1.isSceneZones)
Traceback (most recent call last):
File "/var/polyglot/pg3/ns/0021b9025ffe_2/totalconnect-poly.py", line 157, in discover
self.add_security_device(loc_id, loc_name, device, update)
File "/var/polyglot/pg3/ns/0021b9025ffe_2/totalconnect-poly.py", line 176, in add_security_device
panel_data = self.tc.soapClient.service.GetPanelMetaDataAndFullStatusEx_V1(self.tc.token, loc_id, 0, 0, 1)
File "/usr/local/lib/python3.11/site-packages/zeep/proxy.py", line 46, in __call__
return self._proxy._binding.send(
File "/usr/local/lib/python3.11/site-packages/zeep/wsdl/bindings/soap.py", line 123, in send
envelope, http_headers = self._create(
File "/usr/local/lib/python3.11/site-packages/zeep/wsdl/bindings/soap.py", line 73, in _create
serialized = operation_obj.create(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/zeep/wsdl/definitions.py", line 224, in create
return self.input.serialize(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/zeep/wsdl/messages/soap.py", line 79, in serialize
self.body.render(body, body_value)
File "/usr/local/lib/python3.11/site-packages/zeep/xsd/elements/element.py", line 232, in render
self._render_value_item(parent, value, render_path)
File "/usr/local/lib/python3.11/site-packages/zeep/xsd/elements/element.py", line 256, in _render_value_item
return self.type.render(node, value, None, render_path)
File "/usr/local/lib/python3.11/site-packages/zeep/xsd/types/complex.py", line 307, in render
element.render(node, element_value, child_path)
File "/usr/local/lib/python3.11/site-packages/zeep/xsd/elements/indicators.py", line 256, in render
element.render(parent, element_value, child_path)
File "/usr/local/lib/python3.11/site-packages/zeep/xsd/elements/element.py", line 226, in render
self.validate(value, render_path)
File "/usr/local/lib/python3.11/site-packages/zeep/xsd/elements/element.py", line 284, in validate
raise exceptions.ValidationError(
zeep.exceptions.ValidationError: Missing element isSceneZones (GetPanelMetaDataAndFullStatusEx_V1.isSceneZones)
