Hue Emulator not detected by Harmony Hub
I am trying to use the HueEmulator so I can control a scene from my remote in our theater.
I have the trial plugin installed on PG3 on EISY after updating the ports so the hue is running on 8081 I can see the node Conected ISY connected, and I can flip listen on and off.
When I go to the Harmony app to add the Hue Hub it says nothing was found, and there are no errors in the debug log in PG once the ports were fixed.
I did have some major issues with the hub because it can't be found if a devices in on 5Ghz wifi,  but the EISY is hard wired so I didn't expect this behavior.  It looks like harmny does not give you a way to manually add the hub,
Thoughts? A search of the forums didn't show this exact issue,
It won’t help but I had the same issue using the hue emulator built into Home Assistant. Stood it up and the harmony didn’t detect it. I eventually gave up and just used an automation based on something else in the system turning on/off.
