Is it possible to connect two DSC Envisalink Panel?
I have two DSC alarm system(one in the house and another one in the detached garage. I will like to know if it is possible to connect both of them with one node PG3 or maybe add another node. The house system is working very well but i can't see how to add the other one.
Thank you
Solved by Goose66
@guyhamelin However, I am pretty sure you can install the plugin again in another slot and just set it up for your second panel. It shouldn't charge you again since you already have a license. It won't make any difference on the IoX side, and only a minor resource hit on the PG3x side in running two plugins.
