Yale z-wave lock/eisy/google home integration
I am trying get my Yale assure z-wave lock to work through eisy to the google home portal. It used to work with my ISG. Now I can see and control the lock through the eisy portal but I cut get it to show up as available to the google portal. Any ideas? I am not terribly z-wave centric, I have lots of Insteon stuff.
A little clarification might be needed.  I understand that you can log into the portal, go to ISY web access, and see/control the lock.  However, when you go to the portal and then to the connectivity>google home, the lock does not show up as an available device to expose to google home.  Is this essentially correct?
I can confirm that my Schlage zwave lock shows up in the portal/connectivity which suggests (in my mind) that it is not a zwave issue.  I wish I could offer a solution to this, but the only thing that is coming to mind is that something has become out of sync and that a reboot of the EISY or portal might help.
Edited by oberkc
