Just installed Rachio
@Jimbo.Automates , thanks for taking this NS over.  I debated using it early last year and did not because of no support.  I installed a Rachio3 12 zone controller today and am working to get it configured with NS.
I've added the api key, confirmed remote access is enabled, and rebooted the eISY a couple times.  However, I have the following issues.
1 .Web hook error message (I xx'd out what appear to be a MAC address)
ERROR: 04/12/2025 19:53:39 See log for: Connectivity test to my.isy.io:443 was not successful. Sending: POST to my.isy.io:443 /api/eisy/pg3/webhook/response/xx:xx:xx:xx:xx:xx/17 headers={'Content-Type': 'application/json'} data={"test": 0.08261868723978405} Received: status=500 reason=Internal Server Error
Please confirm portal webhooks are enabled, See Webooks Requirements
ERROR: 04/12/2025 19:53:39 See log for: Unable to discover until webooks are working properly
http://d2z8ydsemzif1x.cloudfront.net/monthly_2025_04/image.png.0c53299b072b2966310db08b537c985d.png
2. When I turned on a zone via AC using Start for 5 minutes, the status does not reflect On until I hit query and does not go back to Off until I hit query again.  I left the shortPoll at 5 and longPoll at 600.
I'm sure its because I'm just starting but would appreciate insights.
Paul
http://d2z8ydsemzif1x.cloudfront.net/monthly_2025_04/image.png.2ca09b90d18c44d0eae6d15aca08631a.png
Is
Edited by hart2hart
I am also seeing the same.
I also tried deleting the Node Server and re-installed it.  Same issue.
