Crash when hub goes down & comes up bad
Just wanted to let the crowd know about a known issue.
Came up recently, but its not the first time.
I have two hubs and when power is lost, cable is lost, or something else happens I can't identify ; sometimes one of the hubs does not come back & "loses master".  Might also happen to one hub owners.
So what that means is one of the hubs will be flashing orange/pink or just orange.
The plugin locks with 'hub is not master' or 'hub doesn't respond'.
Even with a cycling of the power on the hub or hubs, getting them back to blue status the plugin does not recover.
Obviously I cannot fix the Hunter issues, unless I add a smart plug to cycle the power ; but I might be able to make the plugin more resilient.
Just want everyone to know about it & as well ask if anyone else is experiencing this issue & can provide your context.
Solved by sjenkins
  • 2 months later...
So I will close this out with this is not a plugin issue, it was a gateway connectivity issue.  I ended up adding another gateway device so I had one in each room.  Solved the issue.  Seems the gateways do not recover well unfortunately.
