Virtual 3 Way Dimming Problem
Hi
I'm having problems with the dimmer settings in my 3-way switch. The primary switch of the 3 way circuit is a switchlinc dimmer while the secondary switch is a non-dimming switchlinc.
So I've installed the switches and created a scene for the three way light. I have a set ramp rate and an On level setup. From the computer and from the primary switch, it works fine. But from the secondary switch, it goes full on to full off. There's no dimming or ramp rate.
Since the dimming switchlinc is controlling the lights, I'm a bit confused as to why I don't get dimming and the programmable on level. Is there something I'm missing or forgot to program? I didn't link the two manually like the Insteon says to. Everything was done in the ISY program...
Thanks for the help in advance...
Hi ketchup318,
When you select the non-dimming controller in the scene you can adjust the level and rate for the dimmer. Or use Copy Scene Attributes...
Rand
