Goose66 Posted 23 hours ago Posted 23 hours ago A new version v3.2.4 of the Schlage plugin has been uploaded. This version adds last message time, last message, and last used access code state values from lock nodes. Remember that this plugin relies on polling of a cloud service, so changes to node state, like an access code being used to unlock the lock, may not show up to up to 60 seconds or so after it occurs. Please don't set the polling intervals too low to capture this information any faster, because frequent, repeated polling may cause Schlage to start blocking access (a la MyQ). Instead, try and find some other event, e.g., a motion sensor, that may indicate that someone has entered or exited through the door, and in a program use the Force Update command to refresh the state of the lock before checking the state values for further action. See the Release Notes at https://goose66.github.io/nsdocs/schlage-pg3.html for more information.
