Using admin console - Can't connect/LIB_ERRORS-403
If you are suddenly having difficulty to login in admin console, please read this.
We started to release eisy-ui. You can get a summary of the new features here:
One of the goals of eisy-ui is to simplifiy things, and more specifically:
  • Have a single user/password for everything, whether it's for the portal or local access
  • Simplify access by using the standard ports 80 (http) and 443 (https)
Once eisy-ui is installed, which will happen after an upgrade packages, you will be able to use the admin console using either:
IoX Finder should detect your eisy on port 80/443. So if you don't pay attention and use your local user/password when connecting to port 80 or 443, that won't work.
Eventually, you can expect ports 8080 and 8443 to disappear, but for now, they are still accessible for backward compatibility.
