ptcolombo Posted Monday at 06:33 PM Posted Monday at 06:33 PM I posted this as a reply, but thought that I should start a new thread. Have a home system with about 30-40 Insteon devices on it thru the Eisy and a 2413S PLM. All of a sudden yesterday, none of the programs and timers were working. My Eisy looked like it had power and the PLM green light on. Was working fine for months and then suddenly nothing. Could not see the Eisy IP on my router dashboard and would not respond to a ping. Changed out the network cable, tried different port on the switch, unplugged the Eisy -- still nothing. Running IoX was useless with it always not finding it- No ISy found. If I took the Eisy and plugged into a monitor and keyboard, I could see at least something was working on the screen. tried to ping my computer from the Eisy but got "no route to host" message. It's like the network portion is down. Any suggestions? Quote
Techman Posted Monday at 06:45 PM Posted Monday at 06:45 PM If you have a VPN try turning it off. If you enter this address into your browser are you able to see the eisy config file? https://eisy.local:8443/WEB/sysconfig.txt Quote
ptcolombo Posted Monday at 08:34 PM Author Posted Monday at 08:34 PM Techman Nope, don't have and never did have a VPN. Entering https://eisy.local:8443/WEB/sysconfig.txt returns nothing or a message "this site can not be reached". Neither does " https://eisy.local:8443/desc" when you try to enter it with the Add command in IoX. Eisy doesn't seem to be anywhere or reachable on my local network. Quote
Techman Posted Monday at 08:44 PM Posted Monday at 08:44 PM Can you bypass the switch and plug it directly into the router? Also try rebooting the router Quote
ptcolombo Posted Monday at 08:51 PM Author Posted Monday at 08:51 PM Try it on two different switches and directly into the router--no joy. rebooted the router several times, again no joy. Quote
Techman Posted Monday at 09:01 PM Posted Monday at 09:01 PM You could try connecting via wi-fi, It's probably best to submit a support ticket https://www.universal-devices.com/my-tickets 1 Quote
Solution ptcolombo Posted 14 hours ago Author Solution Posted 14 hours ago To put a bow on this, here is the solution. I submitted a ticket on this. Michel, as always, was right on it wishing an hour. After trying a few things, he suggested that if I felt comfortable with it, we would just reflect the Eisy. He sent instructions and links for critical files and the system is now up and running. Quote
