eisy-ui is released
eisy-ui is now officially released. This is still beta software, but it is now included when you "Upgrade packages".
eisy-ui is a service that runs on your eisy that provides our next-gen web interface.
To launch eisy-ui, point your browser to http://eisy.local and login using your portal username and password.
Please note that once eisy-ui is installed, the admin console may need your portal username and password. In IoX finder, a URL with no port will require you to login using your portal username/password. If you see a url with port 8080/8443, this will require your IoX username/password.
More informations here: https://wiki.universal-devices.com/Eisy:User_Guide#Admin_Console
eisy-ui documentation: https://wiki.universal-devices.com/Eisy:User_Guide#eisy-ui
*** UPDATE ***
We are releasing a major upgrade next week which includes an upgrade to the OS. Whenever it becomes available, eisy-ui will be installed automatically by the "Upgrade Packages"
In the mean time, if you are familiar with ssh, you can upgrade this way:
  1. sudo pkg install eisyui
  2. sudo service isy restart
After the above, you may have to manually start eisy-ui if the install did not start it automatically:
sudo service eisyui start
*** UPDATE 08/18 ***
The major upgrade which will enable eisy-ui is not yet released, but it is expected in the next few days. Stay tuned.
Edited by bmercier
Update
