What is correct version 3.2.5 or 3.2.6
@Goose66 good morning.  I'm getting notifications to update to 3.2.6 but it never takes.  I do the upgrade (several times), and it still says 3.2.5.  Is it just meta data in the install package that needs to be updated so that it displays 3.2.6 after the update?
Solved by Goose66
The version is supplied to PG3 by the code. I wish it was just metadata. The move from 3.2.5 to 3.2.6 was simply a file format switch made by git commands. I specifically avoided touching code because I didn’t want to have to retest, but the version had to be changed in the Plugins Store to force the upgrade over the 3.2.5 with the install.sh file in the wrong format.
However, I forgot about the version issue, so I will try to get a 3.2.7 version tested and uploaded tonight.
