Periodic rebooting after 6.0 upgrade
Hello:
I've experienced issues post 6.0 upgrade, including losing the HA VM.
I'm now seeing continual periodic reboots:
  • 10/3 @ 9:18pm
  • 10/3 @ 7:33am
  • 10/3 @ 1:51am
  • 10/2 @ 4:14pm
  • etc....
Thoughts on what might be causing this?
7 hours ago, Fas-Tel said:
Hello:
  • 10/3 @ 9:18pm
  • 10/3 @ 7:33am
  • 10/3 @ 1:51am
  • 10/2 @ 4:14pm
  • etc....
What tells you it's an actual reboot, and not a loss of connectivity or a service restarted?
THe logs show this during each event, and I receive startup notifications in the app:
Time User Code Message Fri 2021/01/01 09:48:42 PM System -5 Start Fri 2021/01/01 09:48:48 PM System -5 Start Fri 2021/01/01 09:48:50 PM System -110026 ./FILES Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/LOG Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/WEB Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/CONF Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/CONF Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF/GLOBAL Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF/GLOBAL/i1 Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF/GLOBAL/i1/nls Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF/f1 Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF/f1/i1 Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF/f1/i1/nls Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF/f1/i1/editor Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF/f1/i1/nodedef Fri 2021/01/01 09:48:50 PM System -110026 ./FILES/DEF/f1/i1/emap Fri 2021/01/01 09:48:52 PM System -110022 ./FILES/CONF/INSTENG.OPT Fri 2021/01/01 09:48:52 PM System -110012 ./FILES/CONF/INSTENG.OPT Fri 2021/01/01 09:48:52 PM System -110022 ./FILES/CONF/UXT.BIN Fri 2021/01/01 09:48:52 PM System -110012 ./FILES/CONF/UXT.BIN Fri 2021/01/01 09:48:56 PM System -140000 my.isy.io Fri 2021/01/01 09:49:26 PM System -140000 my.isy.io Fri 2021/01/01 09:50:26 PM System -140000 my.isy.io
